Vibration
Vibration
Postby Strolls » Mon Jan 28, 2008 12:14 pm
I have a TDCi swb 03.
About 6 weeks ago I noticed a vibration when driving on the motorway - felt like a front wheel needed balancing.
Since then I've had..
wheels balanced (more than once)
Wheel alignment checked
new tyre
Tyres swapped Front to back.
Engine mounts changed (one had a split so changed them all)
Still have the vibration. Most noticeable when applying power.
I can detect it at a lower speed now - about 40mph.
Any suggestions?
Strolls
Re: Vibration
Postby coconut » Mon Jan 28, 2008 11:01 pm
Inner driveshaft spider joint, check to see if there is any splits in the gaiters or movement in the joint. :wink:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Re: Vibration
Postby frosty » Tue Jan 29, 2008 7:43 pm
Strolls wrote:I have a TDCi swb 03.
hi mate please let me no if fords sort your problem coz iv had a noise like a berring gone.only get it bad at certain speeds ie 32 42 and bad at 65 mph,i take 2ford 4a check and they say nothing wrong with it,now im no mechanic but i no the noise of a berring drive shaft wen ther worn out?? im thinking of paying a £125 for a written report from the AA then shuv it up ford arse ha ha
new tyre
Any suggestions?
frosty
Re: Vibration
new tyre
Any suggestions?
frosty
Re: Vibration
Postby Strolls » Sun Feb 17, 2008 11:43 pm
Vibration got worse - very noticeable at 40mph
Have found that inner bearing on the driver's side driveshaft is worn.
Cause or symptom?
Taking apart tomorrow to inspect.
Strolls
Re: Vibration
Postby Strolls » Fri Feb 22, 2008 12:34 pm
You were right
Inner driveshaft spider worn, which also led to some bearing wear.
Strange that I felt no knocking, just a wobblyness - very like unbalanced wheel.
The diagnostic for this was - wheel wobble only present when the foot is on the accelerator. If you take your foot off, it goes away.
Spider - not available on its own.
Driveshaft assembly is the smalles part they sell - £500+
Found it from a factor at £200+
Strolls
Re: Vibration
Postby Grizzle » Fri Feb 22, 2008 4:11 pm
Jesus thats pricey whats miles has it done?
Grizzle
Re: Vibration
Postby Strolls » Fri Feb 22, 2008 5:23 pm
03 plate
70,000 miles
The price is for the whole drive shaft including two spider joints - but is still expensive. So many vehicle companies are making the vehicles a bit cheaper, but loading up on the spares.
THese vans won;t be worth repairing when they get a bit older. A coupel of years down the line, and a part like this fails - the rest of the van might be alright, but the cost of repair this little bit would write it off.
My last van- Astramax lasted more that 15 years.
Strolls
Re: Vibration
Postby transitgeoff » Fri Feb 22, 2008 5:32 pm
no comparison :!:
transitgeoff
Re: Vibration
Postby Muddy Trucker » Tue Mar 04, 2008 11:05 pm
Had a very same fault on a 2005 220 with 20k on the clock , Went backunder warranty and the nearside drive shaft was replaced , Problem solved.
Muddy Trucker
