hi guys
18 tdci 90 ps whats the best fuel cleaner to use???or shouldnt i???
DIESEL INJECTOR CLEANER
MANUFACTURED TO BS EN ISO 9002 SPECIFICATIONS
What it Does
Cleans injectors and injector nozzles, thereby improving the atomisation and spray pattern of
the injected fuel. The product improves combustion and drastically reduces the characteristic
black diesel exhaust fumes. Many tests have been carried out, in many different parts of the
U.K. at official Ministry of Transport (MOT) testing stations, which show immediate exhaust
emission reductions of up to as much as 60%. Power increases of up to 10% can also be
measured, on appropriate equipment.
When used regularly, fuel savings of between 4% and 8% have been recorded. The
composition of TEC-2000 Diesel Injector Cleaner reduces wear in injector
plungers and piston rings, while it cleans. Additionally, the cleaning of piston rings,
combustion chambers and inlet and exhaust ports, together with the minimising of deposits
on pistons, all contribute to improved engine performance. Data from various tests, both in
the field and under laboratory conditions, show that the use of TEC-2000 Diesel
Injector Cleaner improves injector life with regular use.
What it is
TEC-2000 Diesel Injector Cleaner is a multi-functional diesel injector cleaner
which benefits the diesel engine. The formulation has been tried and tested, all over the
world, for the past 20 years. The active ingredients and basic product design are sourced in
the United States of America and the final formulation is arguably the most effective of its type
available in the world, today.
How to use it.
TEC-2000 Diesel Injector Cleaner (in order to reduce exhaust smoke), is best fed
directly into the injector rail from special, Flo-tec Injector Cleaner or inexpensive air powered
equipment, available from various companies. This takes only about 20 minutes.
Alternatively it can be used to fill the fuel filter container in vehicles where this is reasonably
easily accessible. Run the vehicle at idle for about 25 minutes.
Finally, if none of the above alternatives are available, then the suction pipe from the vehicle
fuel pump should be inserted into the TEC-2000 Diesel Injector Cleaner can and
the "return to tank" pipe also inserted into the can and the vehicle run on the contents until the
can is almost empty.
Reconnect normal fuel supply and take the vehicle for a short run, using relatively high
revolutions and full throttle for a short time. Exhaust smoke emission test can now be made
again.
