Reverse gear selection problem
Postby CID Couriers » Sat Mar 29, 2008 1:57 pm
Hi everyone, I am having a problem selecting reverse gear and its driving me mad. When the engine is switched off it seems to select ok but when the engine is running it wont go into reverse. If I stop on an incline and let the vehicle roll back a little then it selects ok. I have changed the cables on the gear stick but this did'nt help. Would be very greatfully for any help. Thanks
CID Couriers
Re: Reverse gear selection problem
Postby coconut » Sat Mar 29, 2008 5:19 pm
More than likely the clutch pressure plate gone weak :idea:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby CID Couriers » Sat Mar 29, 2008 9:31 pm
Hi, thanks for that. I will look at that. Do you know if it is an expensive repair.
CID Couriers
Postby coconut » Sat Mar 29, 2008 9:37 pm
It depends what you class as an expensive repair :lol:
Its about 4 hours labour for doing the clutch plus whatever the parts cost
coconut
Ford Technician
Postby CID Couriers » Sat Mar 29, 2008 9:44 pm
Oh,thats not to bad.Thanks for your help.
CID Couriers
Postby CID Couriers » Fri Apr 04, 2008 8:28 pm
Hi Coconut,
I have had a word with my fitter and he seems to think it could possibly be something else causing the problem as there is no crunching or other clutch related problems with any other gear.Would it cause a problem with reverse first before affecting any other gear selection.Would really like to hear your thoughts or anyone else who has any ideas.
Regards
Dave
CID Couriers
Postby coconut » Fri Apr 04, 2008 9:57 pm
I only say clutch because a little while back I done a police connect which had exactly the same symptons. The police workshops fitted a new gearbox cus they thought it was inside the box, then they brought it into where I work, I thought it was cables, fitted a pair, no joy, box back out (it crunched into 2nd :roll: ) thinking it was a faulty rebuilt one another new box, still the same, couldnt get the clutch to bleed, new master cylinder and pedal was good but still hard to get reverse, box back out new clutch and sorted, reverse everytime :D
coconut
Ford Technician
Postby Altransit » Sat Apr 05, 2008 12:01 am
CID Couriers wrote:Would really like to hear your thoughts or anyone else who has any ideas.
I agree with coconut :wink:
Selection problems that disappear when the engine is off, are (almost!) always the clutch, and always in reverse or sometimes first gear, as those don't have synchromesh assistance :(
Postby CID Couriers » Sat Apr 05, 2008 11:16 am
Hi Coconut & Altransit,
Thanks for your thoughts. I have passed on your replies to the fitter and we are going to change the clutch. Thankyou.
Regards
Dave
CID Couriers
