off to buy a connect 2moro
Postby sparkyork » Thu Jul 10, 2008 1:34 am
hi everyone was wondering if i could get a bit of advise on tranny connects!
im looking at spending upto 5k on one and specifically after the lwb version, found a load around the york area (60 miles) via autotrader.
is there a year or mileage to be wary about? im trying to stray away from 100k miles ones, but again not sure if i need worry about the mileage if its got the service histiry?
also when i go looking 2moro anything i should check out, engine, suspension etc.
also unsure whether to go for the tddi or tdci, is there any probs i could encountor on either one?
i know i sound like im worrying but im just a typical tightarsed sparky who dont wanna get ripped!!!
cheers
rich
sparkyork
Re: off to buy a connect 2moro
Postby sparkyork » Thu Jul 10, 2008 3:24 pm
well i think ive norrowed it down and im off to look at one 2moro:
its the 230lx lwb model, with tdci, good amount of mot, and its 2005 registered with 80k on it and service history. price is 5052.25 inc vat
how does that sound to you guys? also im off too look at it 2moro and would like some pointers for things to look out for?
cheers
rich
sparkyork
Postby Icurus » Thu Jul 10, 2008 4:56 pm
Hi
I've recently brought myself a 53 plate T220 lwb 75ps TDDi connect, see pics in gallery section, and love it :D
Mine had 62k on the clock and cost me £5800 minus £500 trade in on my old Combo van :)
The TDDi is less powerful then the TDCi models and can not be made to make as much power as the TDCi models, but they are better on fuel according to Ford!?
Transit Connect LWB T220 75PS - KnN - HID's
Icurus
Postby sparkyork » Thu Jul 10, 2008 5:41 pm
wow had a look at yours mate, very nice indeed, love the colour! shame the one im looking at is white but hey ho never mind! lol
can u or anyoneelse think of anything i should check for? mechanically, electrically?
cheers
rich
sparkyork
Postby coconut » Thu Jul 10, 2008 8:26 pm
I dont involved in the price side of things, but I can help with the what to look for :P
Check front tyres for wearing on the inner edge (they all do, so just keep an eye on them)
Rear tyres for any disfigurement
Rear anti-roll bar brackets can snap off the rear beam axle (not all connects have anti-roll bars :!: and the metal has been changed from 4mm to 5mm now :wink: )
Engine oil leaks around sump/timing chain area
If the timing belt has been changed (150k/10years upto 04/2006 or 75k/10years after 04/2006)
Check the interior lights work properly and the 'lights on' buzzer works
Check for any vibrations when accelerating
Thats the main things I can think of, so good luck :D
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby sparkyork » Thu Jul 10, 2008 9:52 pm
cheers coconut the van was registered in 02/05 so the 150k one will apply to this one then.
ill be sure to check all theses things out,was there also a product recall on this van?
cheers for ya help
rich
sparkyork
Postby Frag » Fri Jul 11, 2008 6:45 pm
sparkyork wrote:cheers coconut the van was registered in 02/05 so the 150k one will apply to this one then.
cheers for ya help
rich
There was a recall on fuel tank brackets,not sure which Build codes were affected tho.
Frag
Ford Technician
Postby coconut » Fri Jul 11, 2008 8:01 pm
It was from 1/4/2004 to 31/10/2004 for the tank strap recall, thats build dates rather than reg dates though :!:
When you get one, let us have the reg or chassis number and we can check for any outstanding recalls etc :wink:
coconut
Ford Technician
Postby sparkyork » Fri Jul 11, 2008 10:31 pm
cheers cocunut, the reg is se54 swx, chassis number: wfouxxttpu4k72353
well the van seems nice so far!! it was a little quiter when first started but after a 180 mile journey i noticed a slightly different noise, its a noise that increases with revs external to the engine, not 100% but it sounds like something on the belt side of things bit like a squeeking noise but not, if you know what i mean!! after leaving her for a couple of hours and starting her up again, she was quiet then this wierd noise slowly emerged again? any ideas?
also ive drove a few trannies in my time but was wondering theres seems to be like some sort of high freaquency rattley noise when accelerating between 1500 to 2500 revs, didnt hear any vibratin noises as cocunut said but get this noise, but then just about every tranny ive drove makes this noise!!
also! ive been checking the shistiry and its 5k overdue on its anual service, so im gonna get it booked in at polar ford in york 2moro. in the service logs as well there have been no ticks in the major service boxes and it should of had two buy now (unless it has and they simply havnt ticked the box?) ill ring the ford garage that did it and ask them 2moro as well.
well thats it for this post, if someone can shed a bit of light any the above comments and my other post about warranties i would be very grateful.
cheers
rich
sparkyork
Postby coconut » Sun Jul 13, 2008 1:24 pm
The reg goes in but cant check for any recall etc at the minute, will check again later :wink:
The noise might just be the alt belt gone a bit dry and becomes noisey when warmed up or it could be a tensioner/idler doing the same :idea:
The rattle sounds like the usual connect gearbox thrash, nothing to worry about but just mention it when you get the service done to get the techs opinion on it :!:
Now you need to get some pics of it on here :D
coconut
Ford Technician
Postby Icurus » Sun Jul 13, 2008 8:13 pm
Mine also rattles from low revs when I plant the throttle, seems to come from the front n/s of the van, but will disapear if I lift off slightly. Thought at first it might be the Turbo!! :cry: But power is ok and no smoke etc so it may well be as you state and the gearbox :)
Icurus
Postby coconut » Sun Jul 13, 2008 8:28 pm
Good news, no recalls outstanding :D
Only thing showing on OASIS is Arnold Clark fitted an alternator wiring loom at 75460 miles on 30/01/2008 :)
coconut
Ford Technician
Postby sparkyork » Sun Jul 13, 2008 9:25 pm
cheers coconut, got her booked in on tuesday for an annual service, ford also said that arnold clark are very good and not too worry about ticks in the right boxes etc. have kept the existing ladder bulkhead and built round it.
how do i get some pics posted on here?
cheers
rich :D
sparkyork
Postby coconut » Sun Jul 13, 2008 10:46 pm
Pictures are easy :D
I havent got a clue how to do the 'click this link' bit :oops: so go to the forum index, go to the bottom and look for the 'problems, help & instructions' title, click it and look at the 4th thread from the top 'pictures - photobucket instructions' where Luke has done a 'how to' :D
coconut
Ford Technician
Postby the gardener » Mon Jul 14, 2008 12:20 am
did you buy it from a garage around York and if so which one, I got warned off a few when I was looking for a Transit :?:
the gardener
