Hi all
I just bought a transit connect on a 52 plate, its just passed an mot and the guy said that the rear gearbox mount was changed which it does look new. but everytime i change gear and let my foot of the clutch pedal it feels like the engine is going to come through the bulhead!! the clutch works fine and it goes into gear fine surley it cant still be that mount if its new can it? is this a common problem with these vans? also there is a whining noise coming from under the bonnet off side when driving, the drive shaft inner boot is split(gear box side) could this be the shaft/joint etc knackered?
Nick
