I have a 2005 torneo connect 1.8 tdci,it had a small leak of coolant from the egr valve,which turned out to be a crack from one of the welds,anyway got a replacement and fitted no problem.I did notice however that the leak had dripped for quite a time onto the drive shaft bearing but thought nothing of it until a number of weeks later,when a noise appeared to be coming from under the car,a closer look and I thought that this bearing was the problem,Hmm not the case it turned out to be a wheel bearing,so changed both as you do
Ford want about 300euro,sorry forgot to say live in Germany and its a LHD car,but the drive shafts are the same.Have plenty of friends and relatives in UK so any suggestions very welcome.
Thanks and heres hoping
