tt225 wrote:I`ve got the same problem on my mk5, only speed 3 works, is that going to be the resistor aswell?
pace wrote:Thanks for that.
What other models (cars/vans) have the same part? Incase I find a new one on ebay.
Is it easy to fit? Where is it located?
Dan T wrote:tt225 wrote:I`ve got the same problem on my mk5, only speed 3 works, is that going to be the resistor aswell?
Yes![]()
pre '98 is located beside the O/S Headlamp
'98-00 is located behind the dash close to the heater controls
Part is £35 from ford and takes 5 mins to change.
tt225 wrote:Dan T wrote:tt225 wrote:I`ve got the same problem on my mk5, only speed 3 works, is that going to be the resistor aswell?
Yes![]()
Dont suppose you know the part number to make things easy?
tt225 wrote:Mines a 1995 on M so i suppose it must be the headlight type - it`d be good if youve got one
