Indicators too quiet
Postby Tdci_boy » Tue Dec 09, 2008 11:51 pm
Oon of my customers has a 07 connect & wants his indicators made louder (he is old) I had thought maybe a simple buzzer piggy backed onto the flasher relay, although I found the wire that goes 13v to 0 in time with the flashers, it remains at 13v with the indicators off, any one either done this or can think of something that at the mo I'm missing. :D
Transit Custom Limited H1 L2 DCIV, now converted to van by removing the seats etc so now twin side loading doors, fully kitted out with Sortimo racking, always loaded to capacity & averages 35mpg :D
Tdci_boy
GLX Posse
Re: Indicators too quiet
Postby MrMPuk » Tue Dec 09, 2008 11:54 pm
Just fit a buzzer like when wiring up a towbar.
Postby Tdci_boy » Wed Dec 10, 2008 10:11 am
That's what I tried to do but it just buzzed once the indicators were turned off
Tdci_boy
GLX Posse
Postby MrMPuk » Wed Dec 10, 2008 7:51 pm
I meant wire it at the indicators as you would normally rather than at the relay.
Postby sidspop » Wed Dec 10, 2008 7:57 pm
A small buzzer should be available from Maplin, maybe even a beeper.
Run two wires, one from each positive on left and right indicators, through diodes to the buzzer. Then earth on the negative.
Diodes are electrickery, and allow volts through only one way. Suitable diodes are 1N4001, about 10p each, or ask your local TV repair shop.
Hope this helps
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby Tdci_boy » Thu Dec 11, 2008 9:39 am
Thanks for that, I'm going to be installing a door open buzzer for the rear doors soon so I'll take another look then & let you know :D
Tdci_boy
GLX Posse
Postby sport110 » Thu Dec 11, 2008 8:14 pm
Must admit they are very quiet a few times I have left them on by mistake
Ford Transit Connect Sport 110
sport110
Postby Tdci_boy » Thu Dec 11, 2008 8:54 pm
The chap that owns this 1 is about 60 so the hearing is going, when I did the same to his Kangoo it was a piece of cake, just piggy backed a buzzer of the relay. I'll play & let you all know what I did
Tdci_boy
GLX Posse
cron
