N/S rear tail light
N/S rear tail light
Postby Icurus » Tue Dec 16, 2008 7:30 pm
Hi all
My near side rear tail light is not working. All other lights in that unit work fine, even the brake light.
Its not the bulb, tried it in otherside and works fine.
I have out a meter on the connections at the bulb and no power. No power at the van connector too. Its the orange/white cable.
So where does this wire split from the wiring for the other tail light? I guess they share the same cable back to the fusebox from there?
I hate having lights not working.
Transit Connect LWB T220 75PS - KnN - HID's
Icurus
Re: N/S rear tail light - sorted
Postby Icurus » Tue Dec 16, 2008 11:39 pm
OK its fixed now!
Had a look on TIS and it turns out n/s and o/s have their own fuse's!
Was fuse 57 behind the glove box that had blown :oops:
Icurus
