The fuse box is behind the glovebox on my 2008 Connect (as they all are I assume). The sticker on the back of the glovebox that tells you which fuse does what is rubbish. It bears no relation to the fuses at all.... for instance it reckons the fuse for the rear 12v socket is 4th in from the right, middle row. It's not. By trial and error I found it was the second one in.
None of the others are right either, except for the top row where the first 5 from the left are correct but that is all.
