Hi, I have just about finished repairing my accident damaged 2008 Transit Connect T200, but having problems with the Airbag warning light. I have fitted a secondhand airbag, had the drivers seatbelt referbished and had the airbag module reset/cleared.
Now also had on dignostic machine 3 fault codes came up, two of them were cleared but one has remained and the light is still on!
Code is B1915 - Driver airbag first stage capacitance out of range - lamp flash cod: 4. Says to install a new driver airbag wiring sub-harness, but does not say which bit it is describing as a sub-harness. Any ideas?
