Removing Door Handles and Locks - HELP
Postby jldmhifxftc » Tue Nov 23, 2010 8:04 pm
I need to remove the door handles and barrel locks on the FTC.
I am a vehicle wrapper and am doing my van - Ive looked at them and unlike many others that unscrew via the door shut it seems to me that the liner will need to be removed....
Speaking with a body man - he said they are a nightmare.... any suggestions? Diagrams? Help?
Kind regards!
J
jldmhifxftc
Re: Removing Door Handles and Locks - HELP
Postby phillo » Tue Nov 23, 2010 9:59 pm
Hi there ,
Can't help you with regards to the handles but seeing as you wrap , can you tell me if it is possible to wrap the bumpers and arches in the 3m Di Noc carbon film ?
Been toying with the idea for ages and i hoped someone on here might have done it by now.
Cheers
phillo
Postby BLUECONNECTION » Tue Nov 23, 2010 11:34 pm
You need the Ford TIS CD ROM, mine tells you in there but I can't find a way of posting it on here mate sorry, it won't copy and paste and its useless without the pictures, I got mine from a download torrent but I did see them on ebay once upon a time :wink:
BLUECONNECTION
Postby Kent Discos » Wed Nov 24, 2010 12:10 am
phillo wrote:Hi there ,
Cheers
don't think its all that water tight, and would be interested to see if you could get a good enough job out of it!
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby jldmhifxftc » Wed Nov 24, 2010 10:13 am
Some will tell you its not possible - rubber is a bit of a tough go but it is possible - you have to treat the rubber first then apply the vinyl.
The 3M is not actually a vehicle wrap material even though that is the way they market it - the fine print says the warranty will not cover if applied in that way.
I import carbon from a few companies based in Belgium, France and Italy... they look just as good - if not better and are for vehicles.
You can use a sealant on the edges to provide extra insurance against adhesion failure - a lot of work but possible.
Any other queries let me know.
Regards,
J
jldmhifxftc
Postby van mann » Sat Nov 27, 2010 10:32 pm
Take the door casing off and remove the inner membrane.Then using a 20 torx screw driver un -screw the torx from the back of the bezel and remove bezel,then the handle should slide sidewards out from the door.The lock barrels are easy as well.Pull the retaining slide clip down to release the barrel.
van mann
Postby jwb_moto » Mon Nov 29, 2010 6:14 pm
I want to have a go at wrapping my connect and have measured the height of the body at around 70" but im struggling to find any vinyl wide enough to do it in one piece. Is it possible to get vinyl that wide? if not where would be the best place to join the two pieces, horizontally or vertically?
many thanks in advance :D
KartGraffix Need custom vinyl Graphics give me a shout!
Get your Vatuner.com decals here
jwb_moto
Postby aitkenbrothers » Tue Nov 13, 2012 9:16 pm
hi there im having a problem with the barrel iv pulled the retaining slide clip down but the barrell will not come through the door skin either way ???
aitkenbrothers
Postby aitkenbrothers » Tue Nov 13, 2012 9:17 pm
aitkenbrothers wrote:Take the door casing off and remove the inner membrane.Then using a 20 torx screw driver un -screw the torx from the back of the bezel and remove bezel,then the handle should slide sidewards out from the door.The lock barrels are easy as well.Pull the retaining slide clip down to release the barrel.
aitkenbrothers
Postby valetech » Tue Nov 13, 2012 9:58 pm
You need to put the key in the lock and turn the whole lock
molested by:
19s is how we roll
valetech
Postby GKandR4CH » Tue Nov 13, 2012 10:17 pm
valetech wrote:You need to put the key in the lock and turn the whole lock
Yes +1 as I found out a few months ago when swapping doors over.
Read the forum rules
GKandR4CH
