CHECKED BOTH BULBS
LOOKED FOR FUSES BUT CANT SEEM TO FIND ONE
AND CANT FIND REVERSE LIGHT SWITCH ON GEARBOX
CAN ANYONE HELP PLEASE!!!
taz666 wrote:reverse light switch is on top of the gearbox by the gearshift cables
Dagenham Dustbin wrote:I think you get to it inside the cab by taking your gear lever/gaitor out.
taz666 wrote:Dagenham Dustbin wrote:I think you get to it inside the cab by taking your gear lever/gaitor out.
if its there il eat my c**k, no you dont have to take battery out if you look carefully you should see it on the top of the box, might be easier to take air box out
taz666 wrote:right with the air box out look straight down and there is a black plug with 2 wires going to it, thats the reverse light switch, i know its there as i have a connect and just looked and took me 2 secs to find
jd-lee wrote:taz666 wrote:right with the air box out look straight down and there is a black plug with 2 wires going to it, thats the reverse light switch, i know its there as i have a connect and just looked and took me 2 secs to find
nice one, thanx mate, shall have a look in the morning![]()
jd-lee wrote:jd-lee wrote:taz666 wrote:right with the air box out look straight down and there is a black plug with 2 wires going to it, thats the reverse light switch, i know its there as i have a connect and just looked and took me 2 secs to find
the black plug with the two wires going to it... when looking down from the top is it at the back /top of the gear box? if so thats the speedo cable i think as i removed it from my old connect and the reverse lights still worked.![]()
