Turbo Problem??
Turbo Problem??
Postby shaiboyuk » Wed Mar 28, 2012 5:31 pm
ytboi2006 wrote:HI I have a similar problem with my van apart from you can still hear the turbo on mine but it's got no power, the more you rev the engine louder the turbo noise is but has no power. Oh and mine is a 2005 tdci. I would appreciate any help thanks guys.
If you a hearing the turbo spinning up and down, it's not the same fault cause as ours :/
Maybe get it read for fault codes, check all turbo pipes for leaks or blockages
Hope it helps
Cheers
Shaiboyuk
shaiboyuk
Re: help with some advise about van
Postby steve9443 » Fri Sep 23, 2016 7:08 pm
Hi i bought a 07 plate transit van with a injector problem which i had fixed but when it had been repaired engine still ran lumpy and would not idle unless i held foot on throttle, i drove it about 2 miles, it started over revving and it started smoking from exhaust and bonnet and the water started flowing out when smoke stopped it had emptied water and very little oil does anyone know what is the problem please....
steve9443
Re: Turbo Problem??
Postby Harrygm » Sun Mar 19, 2017 10:17 am
My 58 plate connect Owned by me for 12 hours, around 1750-2000 revs has a judder and I'm sure I can hear a funny noise, please tell me this is not the turbo
Sent from my SM-A510F using Tapatalk
Harrygm
Re: Turbo Problem??
Postby M@tt17 » Sun Apr 30, 2017 6:35 pm
Hi I have a 08 tdci connect with Same problem as above loss of power funny noise around 1750-2000 rpm no codes
Help please
M@tt17
Re: Turbo Problem??
Postby 315bblag » Thu Feb 14, 2019 3:12 pm
hi just had turbo problem lost all power thought it was diesel filter changed filter no difference started up noticed suction pipe into engine was collapsed getting wight smoke ,took pipes of turbo ,turbo not turning took air filter off it had collapsed and sucked paper into turbocharged stopped turbo turning blew paper out of turbo with air line, after this checked inter cooler this was blocked with paper from air filter cleaned this out refitted pipes started it up problem solved
315bblag
