and i bet that camper was the 1st 1.8 turbo diesel mk2 transit you'd ever worked on
Luke wrote: 1.8 turbo diesel mk2 transit
yeah a definate trophy contenderrover wrote:Pitty it wasnt in the show n shine
out of a sierraAltransit wrote:Luke wrote: 1.8 turbo diesel mk2 transit
What engine was that
Gurj51ngh wrote:erm my whole van needs sorting mate.![]()
There is like 1 problem which no 1 I mean no 1 has been able to sort out.
My van seems to over heat when I go over 70 mph, You can be standstill rev the crap out of the van and its fine only half way. I have had a new water pump flushed the system several times used the unblock rad thing. The only thing I can think of is head gasket?
I don't expect you to sort it out lol Just would be great if you could have a look and give me your opinion.
O yer also I need help trying to locate the reverse switch on gearbox as my lights have packed up.
fastmower wrote:Hi mate,
The torque sleeve thread is here:
http://fordtransit.org/forum/viewtopic.php?f=18&t=45777&hilit=torque+sleeve
As for the cleaner, throw it all in the tank, or maybe even better, take off and drain (or change) the fuel filter and fill it with the cleaner before replacing it. If the bottle doesn't fill it then top it up with diesel before you re-fit.
Cheers,
Andy
