These are the marine quality waterproof fuse holders, cost £2.41 from local chandlers - 4 off in this install, I don't use crap from halfords etc..
Here i have soldered the wiring, the tape visible is to hold the heatshrink again marine outer and doubled with electric aircraft type inner, if you don't tape it it will just slide down and frap up with the heat and you start again!
One tip when soldering this way is to tease the strands a bit to get them to engage nicely and then use a bit of masking tape near the end of the strands wrapped round so to hold the strands neat for good soldering. 100W iron used.
Here the heatshrink has been shrunk using my zippo lighter and soot wiped of with turps, the two 2.5mm squared panel positives go to 4mm sq. blue
solar cable and the two 2.5 negs go to 4mm black
solar.
Another view.
Fed through for this.
I've actually finished the install and wired up the controller and both batteries and even fitted a voltmeter above the controller on the panel side but did not get any pics done as light was failing so i'll do some today sometime.
I think it all works ok as the voltmeter is illuminated and at dusk when i fitted all the fuses it was reading 7.6v and the next i looked it was out, there were no controller lights lit at that voltage.
Just need to sort out the junction boxes now.
I was thinking of putting a diode ahead of each panel fuse and then i could put a voltmeter behind them for individual panel monitoring but at the mo' i can't be arsed, you also lose 0.3v each diode even with schottky's and panels in parallel do not need any diodes anyway as the controller does that job, the ones pictured in the junction box are bypass diodes that came fitted (ok for series connection) they are doing no harm so i'll leave them on.
