Where to buy Windows?
Postby Smike » Sun Mar 10, 2013 4:13 pm
HI there
can anyone recommend a good place to get Campervan side windows from? I've a 1991 SWB Transit, & the side windows are rusting away to hell around the edges. The best solution I can think of, save from replacing the entire side panels, is to get hold of some bigger windows which will enable me to cut around the bad rust spots.
The other option I thought of was to fit those black plastic panels that you sometimes see fitted to Talbot-type campers, big enough to cover the rusted areas. Any one have any ideas where you'd find a place that sells them?
Cheers for any help!
Mike
Smike
Re: Where to buy Windows?
Postby Northwest2go » Sun Mar 10, 2013 4:29 pm
Can't see from your profile as to where you are.
I got my windows from Northampton, but collected them.
06 MK6 camper conversion, Mercedes C180,
98 Alfa spider ph2 2.0 TS, 2000 alfa spider & 99 alfa GTV V6 3.0.
Northwest2go
Postby Smike » Sun Mar 10, 2013 5:42 pm
I'm in the Isle of Man, so anything I get would have to be couriered over
What was the company?
Smike
Postby Smike » Sun Mar 10, 2013 9:31 pm
Anybody else know of any dealers?
Smike
Postby Northwest2go » Sun Mar 10, 2013 10:11 pm
Northwest2go
Postby Keef » Mon Mar 11, 2013 1:09 am
I'm assuming you have standard Transit windows fitted at the moment.
If you cut the hole larger, what are you going to do with the inner frame that is spot welded to the outer panel around the window aperture?
If the rust hasn't gone too far and you have the style where the rubbers are within the recess (like this),
you may be able to hide the rust without altering the hole by changing them to the style where the rubbers overlap the edges of the recess (like this).
Keef
Postby jumbo camper » Thu Mar 14, 2013 11:51 pm
this is where i had mine from http://www.vanwindows.co.uk/
jumbo camper
Postby Stuart30 » Fri Mar 15, 2013 9:14 am
Ive got a sliding window if thats any good...its for Near side but can flip it over and use odd side...just slides the opposite way. :)
Stuart30
Postby Keef » Fri Mar 15, 2013 12:44 pm
Stuart30 wrote:Ive got a sliding window if thats any good...its for Near side but can flip it over and use odd side...just slides the opposite way. :)
And as you drive down the motorway in the rain, the wind forces the water through the gap and all over the inside of the van :lol:
Keef
Postby Stuart30 » Fri Mar 15, 2013 8:41 pm
Na you just use silcone and seal it all up... :lol:
Stuart30
