Hi I've joined the transit crew and attempting a DIY conversion.
I have just fitted the leisure battery with a split charge relay and have an inverter however I'm confused over wiring lighting, plugs etc.
Some blogs say you can wire the lighting straight through the leisure battery and others say through an inverter or transformer (not sure if these are the same?).
I have no previous experience. My split charge relay kit came with instructions so looking for some help on the next stage. The inverter is also really loud but I'm guessing this is because it was a cheapish one.
Hope someone can help
