SPARE WHEEL INSIDE DAY VAN
Postby mtbcol » Wed Apr 08, 2015 10:18 pm
Hi
Is there a space saver spare wheel (2003 swb low roof t 300) available for my van? or has anyone moved the spare inside there van? I am short of space inside, but don't fancy "tyre weld"
Colin.
mtbcol
Re: SPARE WHEEL INSIDE DAY VAN
Postby Punto443 » Wed Apr 08, 2015 10:24 pm
Moved into the campers section for you :)
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby weseeyou » Thu Apr 09, 2015 12:11 am
why can't you bolt it to one of the rear doors ? :wink:
weseeyou
Postby mtbcol » Thu Apr 09, 2015 8:09 am
Thanks' punto :mrgreen:
weseeyou, I did think of that, but I then thought it may have been to much weight for ther door? door I need a special plate or anything made up, or just drill
some holes ( 3 x I guess) in one of the back doors?
Converting these vans is a BIG learning curve! :shock:
Colin. :D
mtbcol
Postby Terry » Thu Apr 09, 2015 8:24 pm
Hi
Ford do a 'bracket' to mount the spare inside the van, last time I asked it was about £150.
Ford made them for the 'factory' LPG vans as the doughnut tank goes where the spare usually sits.
I can't find my pic of it (different pooter), but I did post a pic under parts wanted, but years ago.
Good luck, they are like hen's teeth.
Have fun
Terry
Pallet Puller
Terry
Postby weseeyou » Thu Apr 09, 2015 8:31 pm
mtbcol wrote:Thanks' punto :mrgreen:
Colin. :D
I'll take a pic of mine if you're interested. its been on the door for at least 6x years and 50,000 miles
I think it was fitted by the original coachbuilder Unlimited horizons back in 1995 when the van was new.
I now have a box fitted in place of the original spare which holds 2x propane bottles under the van with a removable flap inside the van for access
weseeyou
Postby mtbcol » Thu Apr 09, 2015 9:45 pm
Thanks everyone for the replies.
weseeyou yes please some photos would be great, definately interested. if its lasted that long it should be fine for my van too!
cheers
Colin. :D
mtbcol
Postby weseeyou » Sun Apr 12, 2015 6:52 pm
apologies for the delay ...I forgot until I had sat down in front of the tv tonight :roll:
Had to take half the van apart lol
The PO has just used a simple T piece strip of 5mm steel with 2x bolt fixings through the door . It doesn't look all that strong to be honest but its clearly lasted for 6x years + and all way round Europe.
weseeyou
Postby Punto443 » Sun Apr 12, 2015 7:10 pm
I would think you could knock one up fairly easily using a bracket salvaged from a 4x4 at your local breakers yard and flat bar for the inside? You may have to alter a stud or two to suit the transit pcd.
I would think that would prove quite cheap and easy, and look good too with nice cover :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby mtbcol » Mon Apr 13, 2015 5:11 pm
Hi weseeyou
Thanks for the photos, sorry you had to take the door to bits :(
Does the T peice just bolt through the single skin of the door, then the wheel hangs on the bolts on the outside through its own bolt holes with a couple of suitable wheel nuts? I couldn't quite see from the pics, if so I think I get it now. :mrgreen:
Punto443, I did think of that but its the flat bar thing that I am worried about. Is it just like a giant washer that the bracket would bolt to on the inside of the single skin of the door ?
My main concern about this is bending the door skin, it seems the door hinges themselves will take it by weseeyou's comments.
Thanks again, sorry, but don't want to make the old van look even more dented that in already is! :wink: I think I have grasped the ideas now!
Colin. :D
mtbcol
Postby Punto443 » Mon Apr 13, 2015 9:19 pm
Ideally you would want to spread the load as widely as you can to stop the flexing of the rear door, the larger and stiffer the plate, the better it would be, bonding the plate to the back of the door with some panel adhesive or tiger seal would help too.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby mtbcol » Mon Apr 13, 2015 9:26 pm
O.k. thanks Punto. I think this is what I will be doing when the time comes.
Colin
mtbcol
