What is the plastic for?
Postby yotter » Mon Jul 27, 2015 11:17 pm
In the doors of my Tranny underneath the standard hardboard panels there is a transparent blue sheet of plastic stuck down all round. What is the purpose of this? I do intend to insulate the doors but do I need to reinstate the plastic sheet afterwards?
Yotter
Start of the build: http://www.yotter.co.uk/yottervan.htm
yotter
Re: What is the plastic for?
Postby Brains_transit » Tue Jul 28, 2015 2:02 am
It's a moisture barrier, personally I would reinstate it but clear rubble bags can be cut down and used with a spray glue to reattach
Brains_transit
Postby d.e.hill » Thu Jul 30, 2015 10:35 am
You definately need this plastic for a conversion.
As said above, it's a moisture barrier that performs a range of functions. As you breath out warm moist air while sleeping, this can condense on the cold metal sides of the van causing:
- rust in the panels
- damp and subsequent rot of wood
- soaking of insulation (rendering it fairly ineffective)
- interior drips
The moisture barrier stops all this.
The best policy is to insulate directly against the van skin. It's about a 50mm cavity. You can check out my conversion thread to see how I did it. Then stick over the barrier. As stated, rubble bags works, but I used a big sheet of polythene from a DIY store and some PU sealant (silkoflex).
d.e.hill
