by Camper steve » Fri Jan 29, 2016 8:59 pm
i made this myself.
its has a foam rubber seal between the two halves, and spring latches either side so does not rattle and has a fiberglassed inner on the bottom half as these loos can condesate on the outside and drip inside the box. it also has two vents at the back to let air circulate, to minimise condensation.
the loo inside it is a thetford electric flush cassette loo and is 21 litre capacity same as the larger thetford cassette loos. it lasts ok for a family of 4 for a weekend.
i remove the box and put it in an awning when we go camping.
