Hi all.
I know that this has most probably been asked a fair few times but here goes. Ive recently brought a mk7 transit 115 trend and im looking to fit a leisure battery and need to know a few things. 1. Can i install the leisure battery under the drivers seat next to the main battery. If so what would i need to make it secure. 2. What would i need to buy to install it myself. I have seen a few leisure battery split charge kits on amazon for around £40, will this be all i need? All i want to run is a double 13amp socket and a circuit of 4 12v led spotlights. I need to know what id need for this and the easiest way of going about the install as im a bit of a novice when it comes to this kind of thing but i want to give it a try. Cheers in advance for your help guys.
