1994 omega autosleeper
Postby fhwrd » Tue Aug 23, 2022 10:00 pm
Hi I am looking to replace the offside sliding window,
Over the kitchen due to the rubber being perished, can any one tell me if it is possible to just change the outer rubber or where I can get a complete replacement window.
fhwrd
Re: 1994 omega autosleeper
Postby MinorMatt » Fri Sep 09, 2022 11:09 am
Is this one of the ones in the roof?
You may do better asking in the autosleeper forums if its a part that Ford didn't fit?
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby fhwrd » Fri Sep 09, 2022 11:21 am
Hi no its not a roof window.
It is the first window behind the drivers door which is a sliding window kitchen area.
fhwrd
Postby MinorMatt » Sat Sep 10, 2022 11:49 am
The factory type sliding window rubbers are not available, and far from easy to replace. Swapping windows is easy though
2 x 2006 Mk7s
Postby fhwrd » Sat Sep 10, 2022 12:19 pm
Thanks for the info minormatt.
I am looking into total replacement now I know it will be expensive due to the size.
fhwrd
Postby MinorMatt » Sat Sep 10, 2022 2:07 pm
Whereabouts are you? I probably have the window (with good rubber) that you need.
2 x 2006 Mk7s
Postby fhwrd » Tue Sep 20, 2022 4:01 pm
Hi I have measured the window
It is106 cm wide x 60 cm high
This is edge to edge of rubber surround.
If you have this can you give me a price to
Ship to cornwall.
Sorry for delay as van was away having work done
fhwrd
