Could some of you knowledgeable member suggest a location for both a diesel heater and a lithium leisure battery inside a 2022 Transit Custom.
Chris....
dumper wrote:My mk8 will be different to your custom I have fitted quite a few to different ages of transit and drive train and internal furniture so the way I’ve done them is look under the van floor for what area you can get to the inlet/ exhaust/ fuel/ electrical connections mine is bolted to the floor so you need to get to the nuts as well .then look inside the van to see if you have a space that works with your furniture set up .
Mine is a self built van and the heater is on the UK driver’s side just to the rear of the sliding door fitted in a bed bunk and there’s a area underneath in front of the o/s/r spring to be able to fit all the pipe work.
If you’re van is a manufacturer conversion it would be worth talking to them to see how they would fit one.
