2 way split relay
2 way split relay
Postby Jon Boy UK - Wales » Tue May 05, 2009 5:23 am
Hello,
i'm so pleased that i found this forum !!!!
The last time i was this excited i was a teenager on a promise after taking a girl home on a friday night after a few beers and a curry....lol :D
I have a transit lwb high roof....i'm putting together a shopping list so to speak on all the various bits and peices i need to complete the project.
I'm hoping for some advice here to do with electic side of things...
I have been told that i require a split relay to recharge the leisure battery whilst i'm driving.
I know nothing about electrics and i dont want to buy the wrong bit of kit or one thats not up to the job. Could some one point me in the right direction..I saw this at the flee bay: Item number: https://www.ebay.co.uk/itm/110384923127 and woundered is this the gadget that i need? Is it good enough or do i need a better one ...?
The idea i'm trying to acheive:
in the back of my transit i have 2 batterys one will be used much more than the other(1 for lights and a CB radio & 1 for everything else)
Do i join both batterys on the 1st feed and then could i use the 2nd feed for a fridge?
or should i do away with one of the batterys and have feed 1 for a battery and feed 2 for fridge?
could someone send me a diagram with idiot proof instructions on how to wire it all up and what amp wire to buy etc etc and anything else that will help me..
I hope the above makes some sence to you all
Many thanks in advance,
John
Transit 1995 MK5 ~ Series: 120 - SWB Hi-roof ~ Engine: Diesel 2.5 (70PS)
Jon Boy UK - Wales
Re: 2 way split relay
Postby ake » Tue May 05, 2009 6:28 am
try a search on here its been covered loads of times :)
Postby joe1983 » Tue May 05, 2009 12:39 pm
Do the batteries really need to be seperate after the relay? Just wire them back to back with the other output being for the fridge.
2000 T350 Hi-Top and VW Mk2 Golf Gti 16v
joe1983
Postby Jon Boy UK - Wales » Tue May 05, 2009 6:44 pm
hello,
Many thanks for your replies...
I have done a search but due to my lack of knowledge in the electrics department everyones particular wiring configuration appears unique to there needs..
Jon Boy UK - Wales
Postby camperconvert » Tue May 05, 2009 7:05 pm
track down baconsdozen in the freebies section and see if he still has any haynes electics manuals left...... it will help you a good bit if you need to know what to do.....
terry
Terry
http://s481.photobucket.com/albums/rr173/camperconvert/
http://busbuilder.21.forumer.com/
IF IT AINT BROKE - DONT FIX IT
Slowly but surely wins the race
camperconvert
Postby Luke » Tue May 05, 2009 8:35 pm
looking at that on ebay it seems expensive @£20 i got a ZIG unit 2nd hand off here for £25 - i think it does the split charge aswell (i havent wired it up yet) and all the connections are market so easy to wire in and everything is fused :D
Postby iiyama » Tue May 05, 2009 8:51 pm
Google vehicle wiring products. They'll have everything you need......
iiyama
