Hi, I have just finished putting everything back and running the engine. Everything is fine and back the way it was, except cleaner and 'tarted' up. I'm very grateful for the info you gave me, but this 76yr old didn't think that 13mil crankpin hole was so easy to get at. My fuel filter has a drain hanging below it and that sensor/speed gadjet was definitely behind it, so I adopted Burgmans suggestion and marked the crank sprocket with a little dab of white touch-up paint. A couple of rotations after fitting and tensioning new belt it was spot on.
Changed all belts and antifreeze for under sixty quid so I'm very pleased at saving all those garage labour charges!
Recently changed a MAF sensor costing £29.99 on my VW Golf, it took less than 5 miutes to fit. VW wanted £160 including half hour labour!
Thanks again.
