I have made a removable access panel, this is where the microwave is going to sit on a shelf. I made it possible to have access to the lower panel at the floor where the batteries will be going.
I hope this makes sense,
knighty1981 wrote:you could earth it to the body.... but for the power the microwave will be pulling you'll be better off running a wire down... especially when the batteries are right below
how many watts is your mircowave ?
whitemice wrote:Not a fan of high level because of safety/scalding etc
Would choose fused direct wiring in your instance though..
knighty1981 wrote:750watts at 12volts = 62.5amps.... use nice thick cable for that... something like starter motor cable
