Which pop top
Which pop top
Postby monkeynut » Sat Apr 06, 2013 11:29 am
Hi guys
Im still new here and just planning my camper van conversion at the moment.
I want to get a pop top installed on my mk7 swb low roof transit.
I was looking at the Reimo roofs but have been quoted over £4000 installed which just seems over the top.
There is another manufacturer called Austops but they dont mention the transit on there website (i have sent them an email).
I was wondering if there are any others that you reccomend for me to have a look at.
Im after something that is good quality and will last the life of the van with minor maintenance.
Im also stuggling on which insulation to use. My local conversion place reccomend sheep wool but i have read that this can cause the van to rust inside out.
So what do you guys reccomend?
Any help appreciated.
Adam
monkeynut
Re: Which pop top
Postby Tom2023 » Mon Apr 08, 2013 10:19 am
No idea about pop tops however, heat rises so the thermal insulation of your roof is going to be very important. Little point in having super thermal insulation on the walls if the heat just flies out of the roof.
I have never heard of sheep's wool being used in a van.
When you insulate you get a warm inside and a cold outside. Where those two points meet you will get condensation.
You could always paint the inside of the van, or the joints you want to protect, with Hammerite No.1 Rust Beater or Waxoyl first.
If your van floor ends up needing welding then it's going to be a pain in the **** so I would say a good coating of Hammerite No.1 Rust Beater or Waxoyl would be a fine investment there.
Tom2023
Re: Which pop top
Postby barabas » Mon Apr 08, 2013 11:59 am
Damn sight cheaper to get a high roof fitted, plus more room and better insulation.
The two most common elements in the universe are hydrogen and stupidity.
barabas
Re: Which pop top
Postby monkeynut » Mon Apr 08, 2013 12:39 pm
Thanks for the responses.
i hadnt thought about the lack of insulation from the pop top, bu my intention was to close the roof down at night in order to keep as much heat in as possible by reducing the head height, so it would of been ok, and only have lost heat during the day. (hopefully when its already warm outside)
the reason for going the pop top route is because it will be in use daily and i dont want the extra height from the high roof. plus if i wanted a higher roof i would buy a high roof van instead of a low roof van.
i had thought about using waxoyl on the sides of the van as i read that else where aswell.
but it still doesnt help me on what insulation to actually use.
is the kingspan paneling any good as i keep seeing this mentioned, but doesnt seem overly flexible to ensure it covers everything.
also what is the best material to use for the condensation protection sheet. can i just use a big plastic sheet or are there specific materials that do a better job?
any more help would be appreciated.
Adam
monkeynut
Re: Which pop top
Postby barabas » Mon Apr 08, 2013 1:31 pm
As you've probably discovered, there is ongoing debate about insulation and condensation. I've had 2 vans now that were both insulated with ordinary loft insulation and no vapour barrier. Neither of them had any signs of condensation issues after 10+ years, but they did both have mpk rooflights fitted which I'm sure helps a lot. I've just re-carpeted my high top swb and insulated the high top and all the doors with thermal foil bubble wrap style stuff, but haven't had a chance to test it out yet!
barabas
Re: Which pop top
Postby Tom2023 » Mon Apr 08, 2013 4:29 pm
I don't know if putting in a damp proof course sheet in does much good.
At some point there is going to be meeting of Cold & Warm and that is going to produce condensation. Who is to say on what side of a damp proof sheet that condensation will appear.
With a thick coating of waxoyl covering the metal sides & flooring condensation will not be able to get to it and so shouldn't add to the corrosion.
Tom2023
Re: Which pop top
Postby monkeynut » Mon Apr 08, 2013 6:23 pm
there certainly does seem to be a wide difference of opinion on the insulation front.
it seems strange that there isnt a best way for something that you would think is very simple.
guess ill try waxoyl, kingspan(or similar), damp proof sheet, ply line and then carpet.
that way i cover most bases so it should be fine.
any other suggestions welcome of course.
also anyone with more information on the Pop Tops???
Adam
monkeynut
Re: Which pop top
Postby Beegly » Mon Apr 08, 2013 7:46 pm
After insulating and carpeting my van, I would say ventalation is more important.
I spent time stopping draughts to keep heat in but realised that the air got very damp and affected our breathing.
Mondeo 130 TDCI - personal use
30t mobile crane - for work
2004 T280 125 TDCI, 183,000 miles. sold
'96 Citroën ax, 58ps. saved me over £1500 in diesel. SOLD, replaced with
2001 Citroen saxo 1.5 d
Beegly
Re: Which pop top
Postby Honey monster » Mon Apr 08, 2013 8:01 pm
Have you had a pop top before?? Had a Bongo with a pop top and hated it, Its just a tent, Got cold very quick when up and could not sleep with it open as I didnt feel safe in the van, Another thing is noise, Because its like a tent you can hear a fly fart 20 feet away. :D I will never get a pop top again. On the insulation front just use what you think is best, Ive got foil bubble insulation glued to van walls then wool then dpc sheet then ply then carpet glued to the ply :shock: As said good ventilation required to keep air moving around inside.
Honey monster
Re: Which pop top
Postby barabas » Mon Apr 08, 2013 8:17 pm
We've a friend with an Autosleeper T4, the pop-top is solid walls, much better than a fabric one and relatively easy to DIY?
barabas
Re: Which pop top
Postby monkeynut » Wed Apr 10, 2013 5:36 pm
Honey monster wrote:Have you had a pop top before?? Had a Bongo with a pop top and hated it, Its just a tent, Got cold very quick when up and could not sleep with it open as I didnt feel safe in the van, Another thing is noise, Because its like a tent you can hear a fly fart 20 feet away. :D I will never get a pop top again. On the insulation front just use what you think is best, Ive got foil bubble insulation glued to van walls then wool then dpc sheet then ply then carpet glued to the ply :shock: As said good ventilation required to keep air moving around inside.
i havent had a pop top before hence why i am asking, however i have done lots of camping and dont have a problem with sleeping in a tent, so therefore i cannot see wh y i would have a problem with a pop top.
i have already said my plan was to close to top down during the night to avoid any excess heat loss so again wouldnt be a problem considering how easy they are to put up and take down.
monkeynut
Re: Which pop top
Postby northernlad » Sun Apr 14, 2013 10:59 am
We are in the process of developing a pop top for the Transit, should be ready in about a month, we will sell it as a self fit kit for around £1200.
Whilst on the subject we are also looing for someone skilled in Fibreglass who can work in Leeds, we often wonder where all the unemployed are?
Job vacancies
- Van Fitter - to fit camper interiors
- Valeter
- Fibre Glass Laminater/Mould maker
The jobs are at Leeds LS12 6AL
northernlad
Re: Which pop top
Postby monkeynut » Sun Apr 14, 2013 3:34 pm
northernlad wrote:We are in the process of developing a pop top for the Transit, should be ready in about a month, we will sell it as a self fit kit for around £1200.
Job vacancies
- Valeter
Hi do you have any of these fitted yet or are you just still developing them.
Having got various products onto market before I know you need a few examples for people to see before they will commit to something unheard of.
I would be interested in being a guinea pig but would have to be at the right price and I would need it fitted.
Adam
monkeynut
Re: Which pop top
Postby tonylem » Sun Apr 14, 2013 7:15 pm
Job vacancies
- Valeter
Shame I'm not in Leeds, I could fit campers out for you :)
2008 Mk7 MWB 140 T280 High Roof
tonylem
Re: Which pop top
Postby northernlad » Sun Apr 14, 2013 8:45 pm
We already have orders from another camper converter and have been fitting roofs for over 5 years. We will test them on our own vans, we got a fleet of 2007 Transits from a local firm that went bust.
northernlad
