Insulation?
Insulation?
Postby rowantk » Sat Oct 25, 2014 1:53 pm
What type of material is best for insulation and soundproofing? I have been searching posts but not coming up with much. A local guy sells this-
http://www.westcountrycampervans.co.uk/ ... 0cms-wide/
Is that alright? Or could I get better stuff for cheaper?
Cheers
rowantk
Re: Insulation?
Postby rowantk » Sat Oct 25, 2014 3:27 pm
http://www.westcountrycampervans.co.uk/ ... ofing-kit/
Actually he sells all the kit for 100 one....
rowantk
Re: Insulation?
Postby BootsBoots » Sun Oct 26, 2014 10:19 am
Morning R,
Looks ok to me, if it's what they use in conversions it must work.
If they are local to you maybe vist and have a look and if you like what you see the 'kit' may be a bit cheaper collected?
Have fun.
Boots
BootsBoots
Re: Insulation?
Postby TIMO » Sun Oct 26, 2014 10:22 am
personally i think youd struggle to beat kingspan/celotex for sound and heat retaining values mate
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Re: Insulation?
Postby rowantk » Sun Oct 26, 2014 8:40 pm
Ive been considering celotex. W£ill pop into a builders yard and get a quote this week......3-4 sheets should cover a SWB low roof I reacon
rowantk
Re: Insulation?
Postby jolly olly » Sun Oct 26, 2014 8:53 pm
On my mk6 semi hi I used 2 sheets of 50mm and 1 x 25mm for the sides and 2 rolls of the foil insulation for the roof and the spare foil I used for blanking out the front windows.
Life is not a dress rehearsal
jolly olly
Re: Insulation?
Postby whitemice » Sun Oct 26, 2014 9:05 pm
i recommend depron, sell ya a box of white depron------------ 40 sheets 3mm x 1000mm x 700mm or a box of 20 sheets 6mm x 1000mm x 700mm for 75 shekels each delivered, this is genuine stuff and not the crap on ebay etc.
celotex is full of shite eugenicist chemicals
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Re: Insulation?
Postby TIMO » Sun Oct 26, 2014 9:09 pm
jolly olly wrote:On my mk6 semi hi I used 2 sheets of 50mm and 1 x 25mm for the sides and 2 rolls of the foil insulation for the roof and the spare foil I used for blanking out the front windows.
i would sugggest,, the roof is where you need the higher U values of celorex as heat rises directly upwards :D
TIMO
Re: Insulation?
Postby TIMO » Sun Oct 26, 2014 9:11 pm
whitemice wrote:i recommend depron, sell ya a box of white depron------------ 40 sheets 3mm x 1000mm x 700mm or a box of 20 sheets 6mm x 1000mm x 700mm for 75 shekels each delivered, this is genuine stuff and not the crap on ebay etc.
You may have a point Mark,,,, you can get that recycled plastic bottles insulation sheets now too :-)
TIMO
Re: Insulation?
Postby whitemice » Sun Oct 26, 2014 9:17 pm
me mates worked at celotex hadleigh years ago, thought they were tough guys handling the stuff no masks etc. they're all f*** now with health issues, my other mate was a sixth former A level twat and actually did the formulation of the chemicals for the different celotexes and he;s best described as leukemic now or maybe it's just ME? :lol: :lol:
YA GOTTA WONDER WHAT THE HELL IS IN THAT SPRAY ADHESIVE ON THE CAMPERSHITEVANWEBsite above as you're gonna be living and sleeping right next to it as it leeches out :wink:
NWO are spraying them like bugs worldwide with skin intake tranquilisers ya know it's war, smoking fags is the way to go as they know. Linseed oil is better than waxoyl methinks.
whitemice
Re: Insulation?
Postby chris smedley » Tue Oct 28, 2014 8:37 pm
for the walls i used rockwool and for the roof i used flocking that is used in duvets , makes my dayvan warm
chris smedley
Re: Insulation?
Postby Croftylad » Fri Nov 14, 2014 9:29 pm
I built a full camper in my van. To insulate I used regular loft insulation which can be picked up cheaply (£20 a roll in Wickes) It's nowhere near as nasty as the old stuff to use and handle. It's super warm. The advantage of this is it can be pushed into nooks and crannies! Celotex is not much good for this and if your not careful it squeaks like mad!
Antony
Croftylad
Re: Insulation?
Postby k3vyn » Fri Nov 21, 2014 10:29 pm
Transit van LWB High top
I used Celotex, mainly because I acquired it from work for nout but U values are on top.
50 mm all over roof and and down sides stuck it to roof and sides with expansion foam, propped until set, all gaps between boards and posts, ribs ect with foam too.
shaved all foam to flatness with boards.
2` by 1` Planed timber batten to ribs fixed with self drilling tappers to take 6mm plywood, all wiring installed b4 boards, covered with Grey interior carpet.
2 Mistakes that foam dropped down to seat belt mech :lol: and clogged the lot: and rear lights but they were ok.
wheel arch`s boxed in and holes drilled and foam squirted in side.
Roof lining over driver: holes drilled and foam filled in various places to fill and covered with lining to follow with overhead box.
Floor was stripped to metal, primed, painted and original boards back down followed with extruded polystyrene (same as under floor heating boards)
glued and covered with 6mm plywood, to follow was that laminate flooring underlay (the thin white stuff but with plastic backing) and carpet.
I didn't want anything that would hold water, dampness.
I put them £1 throwaway humidifiers in van, one at front and one in rear.
I have noticed now the colder weather is calling the window get saturated and yet to cure that. maybe from a charger always plugged in to run a made up trickle charge to van battery, warm air in van, cold night time ect, I always leave window down a inch.
I am still working on van.
some say Celotex is dangerous, well if that's the case where the correct PPE on installation, once covered your not gonna see it again, after all I guess most of the mechanics on here work in workshops with Asbestos roofs exposed, but untouched its safe environment.
like saying saying don't eat Mc donalds burgers cause you don't know whats in um.
enough said.
k3vyn
Re: Insulation?
Postby biker69 » Tue Dec 30, 2014 9:06 pm
my brother used polystyrene panels on hi varandah lower walls and the difference it made was really noticeable, why not use the thick 'boards' of it to insulate the van wall cavities, its only dangerous when burning.
biker69
Re: Insulation?
Postby jmulvey75 » Mon Jan 19, 2015 7:34 pm
http://pages.ebay.com/link/?nav=item.vi ... 1030469163 have a look at this insulation and vapour barrier
jmulvey75
