loocstac wrote:
My main question I have is it worth fitting a diesel night heater, they are bloody expensive but I'm unsure if it worth the cost? I will mainly be using the van for weekends away May - September for sailing events.
loocstac wrote:Thanks for your replys, I think I'll go for it, they are a lot of money but I'm trying to do the conversion to the best possible standard, and I feel the cold. There is a flat bit of floor in front of the offside wheel arch where I've seen them installed on network rail vans. Reading up about the ebers a lot of people recommend fitting inlet and exhaust silencers so I think I'll get these as well.
With fitting into the fuel supply can I not just T into the fuel pipe to the engine? Or does the engine supply work on a vacuum system?
Looking at pictures of them fitted, is there any way of mounting the heater on top of the 3/4 ply I've fitted or will I have to take the ply up again and cut a section out so the heater just goes through the metal floor?
Sorry for all the pain in the arse questions...
