yes or no = polystyrene 4 insulasion ??
Postby grandads_shed » Tue Mar 15, 2016 9:04 pm
any one got any good or bad points about using polystyrene for insulation in a van ??
i have more than enough to fit out my transit, all sheets are 2 inches thick.
also what would you recommend using to stick it to the van ?? or would just putting it behind the ply trim be oik ?
grandads_shed
Re: yes or no = polystyrene 4 insulasion ??
Postby wronghole » Tue Mar 15, 2016 10:03 pm
I used Jablite insulation panels and stuck them with solvent free instant grab adhesive :D
wronghole
Postby DodgeRover » Wed Mar 16, 2016 12:12 am
Unless you are on a mega tight budget and not going camping in cold weather then I would bin it and use Kingspan instead for insulation its much better than the same thickness polystyrene, if you cut the sheets to fit tightly ply lining should hold it in place, you also need to think about a moisture barrier to stop condensation forming on the inside of the van behind the insulation.
DodgeRover
Postby bigjohnthomas » Wed Mar 16, 2016 9:00 am
doesn't both kinkspan and polystyrene work by trapping air in lightweight bulky materials as still air is a poor conductor of heat ?
so there can't be much difference can there ?
WHoOOoOWAAaa
allcock the vicar
bigjohnthomas
Postby wronghole » Wed Mar 16, 2016 2:09 pm
On my old mk6 rip, l used to have a big problem with condensation which used to make my tools rusty never mind the van.
On my mk7 l insulated all the panels plus the roof and then covered the whole lot with 6mm ply . Problem solved :D :D
wronghole
Postby Kedishen » Wed Mar 16, 2016 9:25 pm
Roof of my van is fibreglass, insulated with white polystyrene sheets.. Sides are insulated with loft insulation. In england, van was always warm during winter (as long as you cover the front windows/door windows from inside or outside).
In portugal, van is warm in winter and cool in summer. Jobs a goodun.
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby Wongo » Wed Mar 16, 2016 9:50 pm
My camper is lined with polystyrene seems good enough and plenty going free down the recycling centre. As someon said its all about air trapped in the material.
Wongo
Postby albo baggins » Fri Mar 18, 2016 3:17 pm
Wongo wrote:My camper is lined with polystyrene seems good enough and plenty going free down the recycling centre. As someon said its all about air trapped in the material.
kingspan is foil coated to reflect back out over heating inside by the summer months :lol: but maintains the best insulation created inside
albo baggins
Postby TIMO » Fri Mar 18, 2016 9:47 pm
Kingspan has better U values than polystyrene per same thickness ,,, though polystyrene will do,,, rockwool is a mad idea as it traps moisture and will rot the van like fook . :roll:
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby bigjohnthomas » Fri Mar 18, 2016 9:54 pm
what the f*** a f*** U value anyway
bigjohnthomas
Postby derv23 » Fri Mar 18, 2016 10:40 pm
U value heat / U value cold :P
MK5 Tourneo.
derv23
Postby bigjohnthomas » Fri Mar 18, 2016 10:53 pm
derv23 wrote:f*** U heat /f*** U cold :P
fify
:D
bigjohnthomas
Postby derv23 » Fri Mar 18, 2016 11:14 pm
:lol:
MK5 Tourneo.
derv23
Postby PLEDGEY » Sat Mar 19, 2016 10:37 pm
This stuff is the bollocks. It's 30mm thick but is the equivalent of 210mm, that's 8 1/2'', of rock wool!. It is expensive though but if you are after bloody good insulation, and want to save space this is the stuff to go for.
http://www.proctorgroup.com/products/triso-super-10
Properties
Thickness 35 +/- 3mm
Thermal Performance Equivalent to 210mm Mineral Wool
Width
1.6m
Length 10m
Area Per Roll 16m2
Weight Per Roll Approx 12kg
Water Vapour Resistance > 500MNs/g
PLEDGEY
Postby grandads_shed » Sun Mar 20, 2016 1:33 am
ok thinking outside of the box a bit ,,,, what about useing waxoyl to stop the damp/condensation build up then use the polystyrene as insulation ??
http://www.ebay.co.uk/itm/HAMMERITE-WAX ... SwX~dWr29X
grandads_shed
