Has anyone got their spare wheel on the back door?
Postby paulrichardson » Thu Apr 14, 2016 6:12 pm
Hi Guys,
I had my spare wheel stolen a little while ago and have not got around to replacing it yet.
I'm going to have a refillable gas tank fitted in May by Propex, if I don't put the spare wheel back where it was they say I can have a bigger tank fitted, which sounds a like good idea to me.
I wondered if the spare could be fitted on the rear door, land rover style and if anyone has done this I would love to hear from them.
How was it done? where did the bits come from? is the door too heavy, with a wheel hanging off it?
Or if anyone has any brilliant ideas what to do with the spare, I'm all ears.
Looking forward to hearing from you,
Regards,
Paul
paulrichardson
Re: Has anyone got their spare wheel on the back door?
Postby Brains_transit » Thu Apr 14, 2016 7:49 pm
Id say the wheel is too heavy for the transit hinges
Brains_transit
Postby ake » Fri Apr 15, 2016 3:52 pm
Brains_transit wrote:Id say the wheel is too heavy for the transit hinges
I agree
Postby paulrichardson » Fri Apr 15, 2016 5:22 pm
Oh dear,
This doesn't sound very promising.
Paul
paulrichardson
Postby cocksocks » Sat Apr 16, 2016 11:10 am
It has a thin plate on the outside about 400x400 MM. thick and another inside think it's 1mm steel
cocksocks
Postby paulrichardson » Sat Apr 16, 2016 12:05 pm
Thanks for the photo.
That's just what I was planning to do.
Have you noticed any extra wear/damage to the hinges.
Regards,
Paul
paulrichardson
Postby cocksocks » Sat Apr 16, 2016 12:12 pm
No but they might be different to yours as mines a dormobil. Also don't really know the layout of your can but my bathroom is behind that door so never really gets opened anyway, I use the other back door for getting in
cocksocks
Postby Keef » Sat Apr 16, 2016 3:45 pm
I've got a Mk3 with the spare wheel on the rear door. It's got a triangular frame fixed through both n/s hinges with the third fixing on the door.
It seems to work ok but I'll be putting the spare back under the van when I get time just because I don't like the look of it.
Sorry, I can't find a photo at the moment and I'm 100 miles away from it.
Keef
Postby paulrichardson » Mon Apr 18, 2016 6:18 pm
Keef wrote:I've got a Mk3 with the spare wheel on the rear door. It's got a triangular frame fixed through both n/s hinges with the third fixing on the door.
I can't think what the MK3 hinges are like compared to my MK7, do we think it would fit on my van?
Regards,
Paul
paulrichardson
Postby ake » Mon Apr 18, 2016 6:28 pm
Regards,
Paul
Hinges are totally different between MK 3/4/5 and 6/7
I think you'd want a carrier with its own hinges fixed to the pillar independently of the door hinges
Postby paulrichardson » Mon Apr 18, 2016 7:17 pm
ake wrote:Hinges are totally different between MK 3/4/5 and 6/7
Hi Ake,
Thanks for the info, do you think such a carrier is commercially available?
Paul
paulrichardson
Postby paulrichardson » Mon Apr 18, 2016 7:50 pm
Bit radical but what if.................
I don't have a spare wheel?
Many of the motor homes aren't supplied with a spare wheel, you just get a can of tyre seal.
Paul
paulrichardson
Postby Keef » Thu Apr 21, 2016 9:19 am
Bad idea. You'll be right up sh*t creek if you get a puncture that the tyreweld won't fix.
My daughter hit a curb and burst the tyre in a new VW that didn't have a spare. What should have been a 15 minute tyre change took half a day to sort out.
Also a lot of recovery insurance won't help you unless you have a spare and the tools to change it.
Keef
Postby DodgeRover » Fri Apr 22, 2016 10:22 pm
How big a gas tank are you wanting fitted? Is it only for cooking/ fridge/ heating or are your running the van from it too? I'm not sure if they are freely available with a vapour rather than liquid take off but you can fit 'torpedo' style tanks underneath the older vans along the side
DodgeRover
Postby paulrichardson » Sat Apr 23, 2016 9:57 am
DodgeRover wrote:How big a gas tank are you wanting fitted? Is it only for cooking/ fridge/ heating or are your running the van from it too? I'm not sure if they are freely available with a vapour rather than liquid take off but you can fit 'torpedo' style tanks underneath the older vans along the side
I'm only going for a torpedo one for Heating/Cooking but 25 is the biggest they can fit in the space I've got left (after water tanks etc).
Without a spare wheel they could probably double that. It would mean much longer between refills.
Paul
paulrichardson
