by pablo42 » Mon Jul 13, 2009 10:01 am
HI
I have had the same problem with mine, worked fine on 12volt, 240volt but would not chill on gas, my problem was definitly the flame. you could tell it was not burning correctly becuase of the colour. It should be a constant mainly blue flame not the pathetic yellow flame that mine had! as mentioned in another reply, it is really easy for rust, spiders webs! and general detritus to cause a problem, so before anything drastic, make sure the gasjet is clear and exhust flue clean, this should be done on a regular basis anyway. a good rule is, if it works on the other powers it can't be the coolent system as it would not work at all, and as for turning it on it's head fro 24 hrs, i have found that driving it around tends to unsettle the coolent just as well! even if it has been standing for a while. hope this helps.
all the best.
