Havnt had chance to get near it till dinner time today.
Took top off carb thinking float might of been stuck, i ve never had a carb in bits before so when i lifted top off heard a hiss and thought its sorted its self and its free. Turned out to be some scale that had gor stuck in the jet.
Cleaned float chamber out and filled it with fuel, stuck top back on and its running well again.
Won a cheap vw t4 drivers seat off ebay earlier on in the week so went to pick that up and set about trying to make it fit.
The floor is ribbed and one side on the base was sitting on a raised rib so ended up cutting 10mm out the side of the base.
Chuffed with it coz its a few years since i had a bash at welding
Gained some under seat storage and have room for a eberspacher when i can afford one.
Tempary b&m seat cover on.
Was looking at chassis plate and remembered seeing a chart on here and after quick search i found out it was built in sept 76,had a look on log book but it wasnt registered till 22/1/77.will have to wait till 2018 for free road tax
Sent from my P330X using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
