lining
Re: lining
Postby Convoy Patrick » Fri Mar 16, 2012 7:32 am
mickyh wrote:Hi all, many thanks for all your help some good tips there. Iv'e already made a start and have done the roof and the sides, have used veltrim and it's quite easy to put on but cutting it soon blunts your blades I can see why you need plenty of them. I have used both spray on and brush on glue and I think the spray on is the better one.Next step is to do around the windows that's going to be fun. :D
'Round the windows' is waiting for me too. I think I'll let you go first. :D
Convoy Patrick
Re: lining
Postby btvanowner » Fri Mar 16, 2012 7:16 pm
I took my windows out,and just folded a bit over and replaced the window
ACCIDENTS ARE NOT FUNNY UNLESS ITS SOMEONE ELSE.....THEN ITS HILARIOUS
btvanowner
Re: lining
Postby Northwest2go » Fri Mar 16, 2012 9:59 pm
btvanowner wrote:I took my windows out,and just folded a bit over and replaced the window
I don't fancy hiring a pneumatic drill to cut through the bonded window adhesive :lol:
06 MK6 camper conversion, Mercedes C180,
98 Alfa spider ph2 2.0 TS, 2000 alfa spider & 99 alfa GTV V6 3.0.
Northwest2go
Re: lining
Postby btvanowner » Sat Mar 17, 2012 7:52 pm
LOL thats a bit dramatic when cheese wire will do
btvanowner
Re: lining
Postby Northwest2go » Sun Mar 18, 2012 7:13 am
OK, I think we may have established some of the pitfalls in carpet lining but obviously not all. On a slightly different slant, where are you guys getting your carpet from? Straight off Ebay and if so which one?
Northwest2go
Re: lining
Postby btvanowner » Sun Mar 18, 2012 3:57 pm
There are loads on ebay,but must say its worth paying a bit extra for the stretchy one...i didnt,it would of saved a lot of hassle round corners and in small gaps.
And doesnt need heating.
btvanowner
Re: lining
Postby Convoy Patrick » Sun Mar 18, 2012 6:15 pm
I got mine from http://harrisonstrimsupplies.co.uk who recommended 10 metres by two metres wide for a swb. And a can of glue for each linear metre.
I've just started working round the windows and it's going on reasonably well. I'm hopeless with the tools normally and although it's not exactly professional standard workmanship it is looking a great deal better than I expected, knowing my history. And once the big chunks are up it is sort of fun working the small sections into place. Not as much fun as some things you can do in the back of a van, but hey ho....
One thing I did discover, when glueing it all in make sure you open both doors. :idea: Why anyone would want to inhale that stuff for fun beats me. Anyway, the headache is easing off and I've stopped feeling nauseous now.
Convoy Patrick
Re: lining
Postby mickyh » Sun Mar 18, 2012 10:29 pm
Got my veltrim and glue from megavanmats.
mickyh
Re: lining
Postby mickyh » Tue Mar 20, 2012 8:53 pm
veltrim is more like wallpapering so my hint is to get yourself a good pair of dressmaking sissors like I have it makes cutting alot easier, hope this helps
mickyh
Re: lining
Postby jls security » Tue Mar 20, 2012 10:25 pm
I found these guys on EBay. Fairly local to me so I called to see them, v friendly an helpful with loads to choose from.
BESPOKE FOAM SUPPLIES
christopher tuda
unit 3 st johns industrial estate
elder road
ol4 3dz oldham, Lancashire
United Kingdom
Phone: 07894244031
Email: chris@tandaupholstery.co.uk
www.jls-security.co.uk. If i can help I will, just ask!
Vehicle security/Hands free/Van Locks/Tracker/Parking systems
jls security
Re: lining
Postby chasnjess » Mon Nov 12, 2012 7:05 pm
Hi going to be using veltrim wall covering I have watched all posts with interest and have been impressed with all the pictured finishes.
I have a couple of questions before I start
1 how forgiving is it with very slightly raised self tapping screw heads
2 Can veltrim go under rubber window surrounds or does it have to be flush with rubber
Any other fitting advice or problems encountered appreciated.................Bruce
chasnjess
Re: lining
Postby matt86_wd2 » Fri Jan 24, 2014 2:26 pm
I am about to make a start trimming my van this sunday I have got mega stretch rather than veltrim as been told its better and easier to use , got from megavanmats .
I will post pictures when done .
Matt
matt86_wd2
Re: lining
Postby Hartley the jam van » Fri Feb 07, 2014 9:33 pm
I got the Mega Stretch Lining Carpet from megevanmats,i've done the panels so far and found it very easy and lots of fun to do. Still got the hard parts to do though,going to start that tomorrow.
Hartley the jam van
Re: lining
Postby matt86_wd2 » Fri Feb 07, 2014 10:01 pm
ive have nearly done all mine now , tonight been doing above the door and around which is the harder parts , Il get some pictures up as promised
matt
matt86_wd2
Re: lining
Postby matt86_wd2 » Fri Feb 07, 2014 11:53 pm
a few pictures
As you can see from the last picture stretched nicely over uneven shapes which was foam to stop bashing your head and the the door aperture.
quite pleased with how turned out . :D
matt86_wd2
