copyed this from another thread, (hope i dont get done for copyright
by screechowl » Fri Aug 26, 2011 2:14 pm
Just do a search for 'photobucket'
http://www.photobucket.com & follow instructions for setting up an account. Then follow instructions for copying & pasting. Or How to post Pictures - Photobucket Instructions
by Luke » Sun Nov 20, 2005 7:42 pm
Basic instructions :-
Here goes..................... what i do is go to
http://www.photobucket.com open an account its free.
Then create an album,
to add a photo click browse then select the photo from your hard disk or floppy or cd,
when it is in your album it has 3 lines of text underneith it, copy and paste the bottom one - which has these [i m g] tags either side [/ i m g]
that should come up as a photo! make sure there are no spaces as well!!
press preview before submit to check its ok!
but remember not to delete the photo from your album or it will also disapear from here!
Hope that helps
First of all open a second browser window, as you would when you first go onto the internet (keep the one that you have Ford Transit Forum open in, this will help when you want to post your pics) go to
http://www.photobucket.com by putting the address in the address bar, not via the link) and sign up for a free account.
You will then be directed to the page for uploading pictures. You can either upload one at a time, or directly under the 'Submit' button there is a drop down menu to select a number to do more than one at once.
To actually upload, click on the 'Browse' button. This will open another window with the pics on your computer in it. Click on the one you want to upload, and then click on 'Open'. This will close the little window and the code for your pic will appear next to the 'Browse' button. Repeat this if you have decided to do more than one at once, then click on 'Submit'. The words *Pictures Added will appear in red above the 'Browse' box.
Scroll down and you will see the pic(s) you have uploaded below, each one with three boxes below it, the bottom one is labled Img. This is the code you need to copy to your post. Click on this to highlight it, then right click and select 'copy' and click on that.
Return to Ford Transit Forum, and open your post. Put the curser where you want the pic to go, then right click and selct 'paste' and the HTML code for your photo should appear on the post! Click on the 'Preview' button and check that the pic will come out before you post ! Then if you are happy, click on 'Submit'!
That's it, you've posted a picture!
Open a second browser page & keep the transit forum page open, then you can keep clicking back to read Luke's instructions slowly a bit at a time. That's how I did it. Its really easy just take your time. I'm dying to see your pics ..
unfortunatly i have never seen the bt water heater you are going to use, so cannot advise much on that, sorry.
my advise may not be right, but I like to give my 10p worth, and an answer even if wrong is nice to see.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
5-Speed Manual - MT75
Drive: RHD RWD
Axle: 4.56
Diamond White 73
