ajpmsport wrote:HI, looking good. Your roof vents how do they seal up from the outside with the roof being ribbed ? cheers
xjrfast wrote:Ordered foam cut to size, got material off ebay and parents handy with sowing maching and all cushions done.
matthew2riches wrote:Seat belt in my eyes is a big no no. Is that a metal framed seat or a timber garden deck chair?
xjrfast wrote:The frame of the chairs is wood but the seatbelts are mounted into 30mm steel box section which is secured through the floor in a few points and has spreader plates underneath. There is no way they are going to move.
tlsjk wrote:xjrfast wrote:The frame of the chairs is wood but the seatbelts are mounted into 30mm steel box section which is secured through the floor in a few points and has spreader plates underneath. There is no way they are going to move.
the seatbelts should be fine for MOT from what i can see in the pics, but i dont know if the seat frame should also be made from steel
xjrfast wrote:tlsjk wrote:xjrfast wrote:The frame of the chairs is wood but the seatbelts are mounted into 30mm steel box section which is secured through the floor in a few points and has spreader plates underneath. There is no way they are going to move.
Cheers Ill find out in July when its mot'dHopefully all will be ok
