The conversions started ....
Re: The conversions started ....
Postby Appy » Tue Mar 17, 2015 8:09 am
Hi Jon,
The bearings came off ebay, if you search " BEARINGS 6200 - 6209 2RS " it will come up with list of sellers, I used the first listed Bearingoptions, cheap and really fast.
I ordered the bearings before ordering the Unistrut, and took dimensions off the unistrut website. When my strut was delivered It differed slightly in size from original 'Unistrut" and I needed to reorder. Ordered 32mm O/D and found 31mm would have fitted but used 30mm the next stock size.
To save you time they are listed by QTY 10x Type 6200 2RS I/D 10mm O/D 30mm Width 9mm
I used the 2mm thick heavy duty strut .... if you are using light duty, its likely a larger diameter will fit so definitely measure first
hope that helps, let us know how you get on .......
regards Colin
Appy
Postby slingshot2000 » Tue Mar 17, 2015 2:44 pm
Hi Colin,
Thanks for the prompt reply and the ebay links.. I don't think I will get this done for a couple of weeks, but once I do I will make sure I post some photographs.
Thanks again
Jon
slingshot2000
Postby ian__lo » Tue Mar 17, 2015 9:30 pm
Nice project, I've been keen on a camper since I lived in a couple wicked vans in new Zealand, it's a great way to take time off! Being a mid roof is a plus too which I'm keen on down the line... You'll have some sweet times in that camper!
ian__lo
Postby Kedishen » Mon Mar 23, 2015 12:13 am
Very jealous of your roof rack.. Nice work
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby Appy » Thu Mar 26, 2015 10:04 pm
@Ian @Kedishen cheers for the comments guys Image
I've recently installed an Asus Nexus 7 Android Tablet over the front of the Double Din Radio space. The van had the Tacho mount fitted when I bought it, and the original Ford radio was missing. I used a existing Single DIN pioneer radio and stuck it in the Tacho housing. It all fitted in well
I have the steering column Stalk for the radio and would like to get it back in use, I dont think my Pioneer DEH P7000 USB can accept a plug
Are there any independent radios out there that will accept the radio stalk ( I guess with some sort of adaptor) something I could pick up 2nd hand preferred
Or if thats a nogo ... are there any Ford radios in a single DIN that will plug and play on the Stalk
Cheers Colin
Appy
Postby Kedishen » Fri Mar 27, 2015 2:13 am
Wats the credit card slot for?
Kedishen
Postby Appy » Fri Mar 27, 2015 8:10 am
that panel is a new panel from fords. the original was a bit hacked about. i assumed they were all like that ?
colin
Appy
Postby ake » Sat Mar 28, 2015 9:57 pm
Kedishen wrote:Wats the credit card slot for?
Strangely enough, it's for storing a card!
Postby dodgy01 » Sat Mar 28, 2015 10:01 pm
and yes they are all like that
dodgy01
