Has anyone got their spare wheel on the back door?
Re: Has anyone got their spare wheel on the back door?
Postby ned » Sat Apr 23, 2016 11:59 am
You could go to a breakers yard and get a spare wheel carrier off a 4x4 that hinges off the body work. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ake » Sat Apr 23, 2016 2:08 pm
paulrichardson wrote:
ake wrote:Hinges are totally different between MK 3/4/5 and 6/7
I think you'd want a carrier with its own hinges fixed to the pillar independently of the door hinges
Hi Ake,
Thanks for the info, do you think such a carrier is commercially available?
Paul
Not that I'm aware of, but you could probably modify something from a LandRover or similar
Postby paulrichardson » Wed Apr 27, 2016 5:27 pm
Hi Guys,
I've decided that I'll replace the underfloor carrier and try and protect the vulnerable bit of cable.
I have been told there are two different carrier systems for the MK7 FWB SWB van, does anyone know the part number of the correct part.
Or where I can find it on the net ( I can't look at mine as it's gone).
Regards,
Paul
paulrichardson
