johnporter11 wrote:Can I just clarify what you've done. Your vehicle is LHD. You've taken the positive from the CCP down at the left hand side of the seat.No, I connected the dc-dc charger directly to the battery terminal as it needs a higher amp fuse (75-80) than the one on the CCP (60). See below.
Regarding the negative leads, where are they attached? I note you haven't used the stud on the chassis side of the voltage monitor on the negative battery post.I don't quite understand what you mean by this. Which stud are you referring to?
Where exactly is the fuse box you mounted? See attached picture
And is it connected to the same CCP terminal you appear to have used for the charger positive? The fuse box is connected to the CCP and grounded to the chassis.
I'm afraid I haven't got to grips with this whole thread. I don't understand how the D+ signal is generated. This is generated when the engine is running, it tells the dc-dc device that it's safe to start charging without draining the leisure batteries
I have a very similar setup to yours, but RHD and using the Renogy 50a DCDC with MPPT. I attached the D+ charger lead to an ignition live in the fuse box under the dash. The positive comes direct from the battery, with the breaker mounted in the same place as yours. My system seems to be working fine.
Kwiks1lver wrote:Looks like a decent setup John, good job! I've not heard about terminating on the chassis side of the terminal. I'd better look into that I guess!
One question on your setup - why haven't you gone for a bigger breaker for your solar isolator? 20A won't get you far if it's gonna push 25A through. Or have you got a lower-rated PV cable?
