Stanyouphoto wrote:I am embarking on a Ford Transit 460 Minibus conversion too. One question I have for you though is that of the weight of the van. We took ours to be weighed after stripping out the rear (seats, trim etc) to it was a bare shell and it came in at 2.7 tonnes (2700kg), leaving us with 800kg left. Are you facing the same issue with yours, or am I just stressing based on the following weight predictions that I am planning (not even finished yet though);
Person weight (75kg pp) - 150kg
Fuel tank - max - 58kg
Fresh water tank - max filled weight - 100kg
Grey water tank - max filled weight - 50kg
Tech / Camera equipment - 20kg
Kitchen / Food etc. - 20kg
General belongings (20kg each) - 40kg
Total - 438kg
Remaining - 367kg
Also, for the aircon removal, I just had a local aircon engineer come and drain the system and then unbolted the unit from the back. I plan to remove the pipes and tig weld the ends off so that the system can then be re-gassed so I can use the aircon in the front again.
Let me know your thoughts on the weight.
Thanks,
Tristan
JamesHow wrote:Does anyone know how much space there is in the ceiling lining either side could you put some storage in for light items either side?
Cheers James
.jpg)
