I've got a full set of flat aftermarket glass in mine, lovingly fitted by those who did the minibus conversion after it left the factory. I'm gearing up to welding up at least five of the windows as some of them just let water in all the time (hence much welding when I first got it). Who ever decided to cut out the single large 'window' panel at the back and put in two separate windows with a stupid plastic filler in needs a large slap as it's stupid (and stupidly realised as it overlaps the window frame at the top and bottom) and lets so much water in you don't need a pump for the taps. Currently sealed using fish tank sealant, but not ideal as the rot has already got in and will be again as the rubber gets older.
And the rust doesn't just rot the window frame inside, it then drops down into the wheel arches and rots them out where they join the floor and to the bottom of the sill too.
Not that I want to worry you or anything.
For now I've put coloured film over those windows I'm not using, and one small window has been replaced with a piece of aluminium sheet as it has the exit vents for the fridge in it.
