Digahole78 wrote:That great to hear. I posted my results after seeing a few vague posts saying it could be done but nothing that gave me full confidence. With regard to gap left in carpet, I have opted to extend ply floor from rear into that area as I'm doing a camper / work van conversion. Seems to have worked nicely. I left those studs on for now just in case I find a use for them but no doubt I'll cut them off at some point. If you come up with any nice designs for 3d printed covers please do share.
dumper wrote:I extended the floor in the front of mine even with it being a single seat model and then when I lowered the handbrake lever and cut down the cover it gave me something to screw it to .
dumper wrote:I removed them as it made it a lot easier to get my fat backside into the rear of the van I used a large flat washer to cover the holes up after removal you also have to swap the seat belt anchor over I’ve not had to do this part myself but from posts on here it can be done .
Blizz wrote:dumper wrote:I removed them as it made it a lot easier to get my fat backside into the rear of the van I used a large flat washer to cover the holes up after removal you also have to swap the seat belt anchor over I’ve not had to do this part myself but from posts on here it can be done .
I'm searching for an armrest as my OEM single passenger seat hasn't one.
I guess you left the tilting mechanism inside the seat.
Would you sell the armrest?
Cheers,
David
jb911964 wrote:Hi, I'm struggling with the same problem, I want to change the double seat in my 2023 transit custom for a single seat. I have the seat but no seat box can't find a seat box for the passenger side anywhere. Did the drivers seat box fit straight in and did all the bolt holes line up ok?
Thanks in advance
Jim
