fridge vents in side
Re: fridge vents in side
Postby ablaze79 » Sat Apr 25, 2009 2:34 pm
Hiya :-)
I've converted two vans into campers and had different results with each!
I fitted electrolux 3 way fridges in each.
On the first I just cut the small flue hole out for the burnt gases, no large vents top and bottom.
This worked fine and there were no smells of gas within the van and no adverse effects.
On the second, I once again fitted a 3 way fridge (alittle lerger this time) and I too did not want to cut top and bottom side vents out. I did however cut the flue hole in the side and added some extra mesh covered holes in the floor.
However on the second conversion I am getting lots of gas fumes within the van from the fridge!! :? On this one I WILL be cutting out a top and bottom vent, I am afraid of being gassed too!
Foprtunatly may van is white and looks like a camper any way (Carver water heater cover fixed to the side and fridge flue gives me away).
Hope this is of help to you?!
Apollo
ablaze79
Postby lostpaul67 » Sat Apr 25, 2009 2:36 pm
Luke is that not a vent behind the rear most window, may be plumbed to that :wink:
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby Luke » Sat Apr 25, 2009 3:09 pm
ablaze79 wrote:Hope this is of help to you?!
Apollo
thanks :D i do want the van to be safe without a doubt :!: but if i can get away without cutting (or as little as possable) i will :lol:
lostpaul67 wrote:Luke is that not a vent behind the rear most window, may be plumbed to that :wink:
mabe - i've been having another look and i think i've found the vents :)
they appear to vent into the rear of the van :shock: :? if they are the fridge vents there must be some channel or something in the tailgate to vent to the outside :?
Postby Luke » Sat Apr 25, 2009 3:12 pm
barabas wrote:
Luke wrote:i still havent cut the vents :lol: but i was browsing and i came across this :arrow:
http://www.alljapanesemotors.com/details.php?id=55
appears to have a fridge rear passangers side
yet doesnt appear to have any vents in the side :?
dont know if they are painted green and very well discuised or it doesnt have any :? :?
Looks like internal vent mounted in the end of the cabinet, probably struggles to cool on a hot day...
missed this post :oops: but looks that way :D
Postby Breakdown Biker » Sat Apr 25, 2009 8:42 pm
Hi Luke, just been reading through this thread and there seems to be some confusion. :? I am 85% into my camper conversion and had to research the fitting of a fridge because I have a window where one of my vents would need to go. My enquiries revealed that the large vents normally seen on the side of a camper are designed to allow cool air to ciculate NOT to dispel CO fumes. It is possible to fit a vent in the floor and roof, provided they allow enough volume of cool air to ciculate. All gas fridges need to be vented through an exhaust which if properly fitted should not allow fumes back into the van. A CO detector is a must if there are any gas appliances in a van but, if the appliances are regularly serviced, you should have no problems.
I ended up fitting one large vent at the bottom and a powered mushroom vent in the roof. I only use the fan on very warm days and have had no problems. The vent kits sold by the likes of Dometic are designed to produce the neccessary volume of ciculated air in the minimum possible space, but there's nothing to stop you having a larger area behind the fridge. Just ensure the exhaust is properly sealed and fit that CO alarm :!: Hope this helps :)
Where would ya be without a can of W.D?
Mk5 hicube minibus camper conversion
viewtopic.php?f=58&t=43816
Breakdown Biker
Postby merlin » Sat Apr 25, 2009 9:55 pm
regards vents the large vents on outside are only for keeping the air cool around fridge but will need gas outlet vent fitting which you could pipe up to your roof so not as visable
[IMG]http://i724.photobucket.com/albums/ww241/merlin-08/bessie049.jpg[/IMG
merlin
Postby barabas » Sun Apr 26, 2009 11:10 am
merlin wrote:regards vents the large vents on outside are only for keeping the air cool around fridge but will need gas outlet vent fitting which you could pipe up to your roof so not as visable
You've got to have a vent in the bottom of yer van as carbon monoxide is heavier than air so it tends to sink and will 'pool' if it has no hole to drop out of.
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby Luke » Sun Apr 26, 2009 11:55 am
good info cheers guys 8)
a vent in the floor is no problem at all :D
