Wow! nice drawings Joe, thanks for the effort mate, you've been a great help.
I bought a pair of the plastic table hooks, they were only 1.73, but too flimsy for this table, so I'm gonna use them on a wee side table I had planned.
I ended up buying shelving brackets from Wickes and adapted them for the table
I cut the size I needed then drilled and countersunk a second mounting hole. I had to cut it with the grinder as a hacksaw was only scratching it
Then I mounted them on the doors
I put the brackets on and offered up the table, checked it was level and marked the brackets underneath.
Had to use a couple of nuts as spacers
It was a wee bit fidly to fit the table on but after a wee adjustment it was fine. It's good and sturdy, and the brackets won't be obtrusive when the table is off.
Thanks guys, I couldn't have done it without all your help
