Wiring up a 3 way fridge to existing relay?
Re: Wiring up a 3 way fridge to existing relay?
Postby welshrussell » Thu Apr 16, 2009 9:24 pm
OK does this sound more like it..... :roll:
1) Neg wire of fridge earthed to chassis
2) Pos wire of fridge to relay 87
3) Wire from relay 30 to alternator terminal B+
Do I now need to connect this new relay to the existing one :?:
Do good things - and good things will happen to you!
welshrussell
Postby ake » Mon Apr 20, 2009 12:35 am
yes so that the new relay will come on after the first one comes on. On the new relay connect terminal 85 to earth and terminal 86 to terminal 87 on the existing relay, hope this helps :)
Postby welshrussell » Mon Apr 20, 2009 10:15 pm
ake wrote:yes so that the new relay will come on after the first one comes on. On the new relay connect terminal 85 to earth and terminal 86 to terminal 87 on the existing relay, hope this helps :)
Superb - I think I've finally got it :o
My final question is.....
Will it be ok just to twist together and then crimp a spade connector to the new terminal 86 wire and the existing terminal 87 wire (old relay) :?
If so, that's me ready to go done to Maplins for a relay and some wire.
Any suggestions on the most appropriate gauge of wire would be very helpful :oops:
Thanks Ake for your help 8)
welshrussell
Postby ake » Mon Apr 20, 2009 10:20 pm
Will it be ok just to twist together and then crimp a spade connector to the new terminal 86 wire and the existing terminal 87 wire (old relay) :? Yes that will be okay but put a small fuse inline 5 amp max
Any suggestions on the most appropriate gauge of wire would be very helpful :oops: For the switch sides of the relay you only need about 0.75mm2 for the load side I would recon about 3 mm2 (not sure what that is in awg)Just make sure that it rated to the same number of amps as the fridge
Nae problem glad to help, I can't wait to see it when its all done :)
Postby welshrussell » Mon Apr 20, 2009 10:27 pm
Cheers Ake - you've been a massive help :D
Hopefully Dan T should onlt be a couple more weeks with getting my van resprayed and then I can get stuck into tarting up the interior - can't wait 8)
welshrussell
Postby welshrussell » Thu Apr 23, 2009 9:08 pm
Hope you see this Ake :!:
I had a look at the sticker inside my fridge and where it has a box for 12V amps - the box is blank :roll:
The fridge is an Electrolux RM212, so I guess quite common for 1970's campers.
I read somewhere a fridge like this draws about 10amps - does this sound right :?:
I'm just thinking about what you said about getting the correct wiring.
welshrussell
Postby ake » Fri Apr 24, 2009 3:32 pm
Sounds about right, So if you think its 10amp then wire it for 15 and you'll not go far wrong :)
Postby BigNeil » Fri Apr 24, 2009 3:58 pm
ake you should just pop down and help russell he amkes tea and coffee i bet and young marc may get a biscuit :wink:
BigNeil
Postby ake » Fri Apr 24, 2009 5:04 pm
BigNeil wrote:ake you should just pop down and help russell he amkes tea and coffee i bet and young marc may get a biscuit :wink:
:lol:
Postby welshrussell » Fri Apr 24, 2009 9:52 pm
:lol:
:D :D :D :D :lol:
Ake the invite is always there - just wished I had a van to show you right now :wink:
welshrussell
Postby ake » Tue Apr 28, 2009 6:16 am
I'll get there one day :)
