Bryandarragh wrote:Hi white mice
Lovely job! I bought a mark 5 ambulance and your pics have given me some great inspiration.
Going to my brothers this weekend to (finally) get started on getting the auld girl converted.
Hope to get pics online starting with the before pics this weekend.
Bryan
Cool,
Strip everything out and estabish where all the wood/metal framing is betwixt the fibreglass body panels in sides and roof for getting a fix. Use stainless screws/bolts for fixings to floor and do any welding to spring hangers/chassis etc. beforehand.
I fixed 2x1 wood full length to the sides internally for the main strength of seating/bed and pre-drilled 1x1 uprights in order to screw using selftappers and cupwashers 12mm ply formers shaped to van profiles onto them. The internal van lengthwise wood structure was at the perfect height of seating (2x1 longeron goes only as far as shower/fridge panel on offside.) i used 1x1 longerons let into the 12mm ply upright formers to fix overhead lockers in 7mm ply.
I used 1x1 screwed into original wood floor to get fixing for all formers and front panels.
Seat surfaces and fronts are 7mm ply and top-hinged at their rear for access, with two 12mm formers giving three compartments inside and seat support these are over wheel-arch and were planned so that the rear compartment each side can take a waste container with a 25l water container above each one for travelling these get bunged outside when camping.
1x1 is used to get fixing and strength to seats and a bit of work with a woodplane on front top/bottom lengths gives the important ergonomic angled recess for feet/sitting/walking clearance comfort.
Uprights and longerons are fixed to the van wood structure which was accurately found using 1mm drillings to locate and then positions were drawn on internal fibreglass with permanent marker
Gas copper pipe is run across van for cooker is outside underneath from gas locker and enters van again through floor on opposite side in wardrobe and runs through it and seating to cooker/oven, fridge and heater is similar only no run outside is needed.
Matt white laminate and Dulux satinwood yellow with clear satin varnish on 7mm birch keeps things light with a long lasting easy to clean and wipe interior.
I used lithoplate from a scrapyard to line the cooking area and rear of fridge with.
It took me 3 months more or less everyday but nothing has ever failed or needed painting or replacing in almost 20 years.
Main tools needed are a jigsaw, handsaw, circular saw and plane.
