1978 mk 1 camper
Re: 1978 mk 1 camper
Postby walt1984 » Sat Jul 30, 2016 4:34 pm
Started fitting the new split charge wiring this afternoon . Managed to get relay fitted under battery tray out of sight and wired up.
Also tested the night heater i bought as spares repairs. Image
Got a few neighbours asking what it was and what i was doing to landrover, they still looked confused when i said i just need some power.
Abit miffed coz ive got to go to a BBQ now and i know ill get bugger all done tomorrow.
Sent from my P330X using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby walt1984 » Wed Aug 03, 2016 9:57 pm
Been slowly getting on with split charge upgrade and night heater install.
Heater inst finished because I'm waiting on a part turning up.
Tonight I managed to get the radio wired to the leasure battery and fit switch for 2 speed heater fan.
Pictures are abit poor because flash won't work when batterys low so had to use a torch.Imagehigh and low switch wired up.Image I used a mk345 resistor and used what would be 1 as the low. It still needs mounting but its too dark now.Image switch mounted in one of original holes.
Part of split charge wiring done at the weekendImageImageImage
Not a good picture of relay mounted under battery tray
Sent from my HTC One S using Tapatalk
walt1984
Postby walt1984 » Sun Aug 21, 2016 7:35 pm
Was in for test yesterday (Saturday morning) booked for 1st job at 8.came home late friday, slept in Saturday. Dashed out at 8 and battery was flat, jumped it off then on way to mot exhaust started blowing on drivers front pipe to manifold.
Got there at 8.15,one car on ramp another waiting, sat about had a brew till cars were gone then i gets "walt. Put y camper on ramp am off t pick a van up"
Had a nosy round, bolt missing off exhaust hanger, greased king pins and hand brake cables and oiled ujs.
Passed with a couple of advisorys . Image
Off to work after.
Today ive got eberspacher fitted, plumb and wired up, taxi heater plumbed and wired and split charge wiring connected.
All working
Parked on kurb and ramps under wheels make it easier to work on. ImageImage
Wiring extended. Image
Temporary fuel tank. Image
Fair way taxi heater and dacia expansion bottle. Image
Just need a cap.
walt1984
Postby jonochap » Mon Aug 22, 2016 12:56 am
Looking good Walt and good news on the test :)
Owner of not so troubled puk :)
jonochap
Postby walt1984 » Mon Aug 22, 2016 7:22 am
Thanks jono.
Looks rough on top but its getting there underneath.
walt1984
Postby robbie.cee » Thu Aug 25, 2016 10:35 pm
Ello mate great work. Cutting out may be too retarded making fuel evaporate..my essex v6 did it. Red hot exhaust manifold and boiled fuel. Timed it up about 30 degrees using timing gun and was sweet after!
You'll want about 6 degrees btdc with vac advance pulled off dizzy and vac blocked
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby walt1984 » Fri Sep 02, 2016 1:26 pm
Ill have to check timing.
Alternator had packed up on bank holiday weekend.
Struggled to find anywhere that stocked one or a marine mechanic.
Got home in day light, left old alternator with local motorised discounts telling them what its off and want to upgrade to a bigger output.
they rung up this morning saying that they can get a left handed alternator but it wont have the black plastic lucas cover on the back.
Not a problem.
We supply alot of these alternators to canal boat yards
Sounds good when can you get one?
We can get one for 4pm.
Great, how much? getting ready for a big shock
£45 plus vat. For a 65Amp alternator.
Will be better than the standard 27amp one just need a bigger wire.
walt1984
Postby walt1984 » Sun Sep 11, 2016 7:16 pm
Fitted new alternator just so camper can be run and moved.
The new 1300mm belt wouldnt fit but managed to prize old one on, must of stretched a little over time.
Old lucas plug fits in back but it also has a B+ post to connect too.
Had jump leads but thought id just try to see if it would start as it was faced into sun.
A few slow throws and it fired up
I know it has the leisure battery to run from but i dont think the mk7 would of driven 90miles through towns and villages, run with side lights on closure to home and the started 2 weeks later with a duff alternator.
walt1984
Postby robbie.cee » Fri Sep 16, 2016 6:19 pm
Sorry should have been 13° btdc for essex v6 (6° btdc pinto) for timing advance
Had
MAKE IT FIT
robbie.cee
Postby walt1984 » Thu Feb 22, 2018 4:58 pm
A long over due up date
Where did I get to.
Camper has been used but just no updates
January 2017 we had all the brakes off stripped cleaned and new pads
Exhaust stripped coz it was blowing again on drivers manifold.
Spring time the starter died so a new old stock replacement fitted
Around a month later the leasure battery died along with the starter battery ened up getting a jump of a Bentley fitted with a 6BT cummins engine.
A fully working hob unit came up now have hob and a gillie.
Mot time and the only fault really Was the cheap led bulbs in the rear lights
The said belt that had stretched over time to fit the new alternator stretched a little more and snapped one Friday night on route to a steam rallly luckily local autoparts was still open.
Work is needed this spring on the roof lights as they are leaking
After looking at bigger better mirrors that are in keeping with the look of the mk1s I've bought a reversing camera and hoping to hide the camera under the rear step
Went to the camper last weekend even with the choke stuck once it pulled fuel up it started and idled happy, not bad to say it's been stood since September.
Show season will be starting at the beginning of may and we're hoping by then it's free to tax and maybe test exempt but think it will still be going in for a quick once over.
walt1984
Postby rhinocharge » Sun Mar 04, 2018 6:41 pm
What a cracking camper van. Great to see! 8)
rhinocharge
Postby walt1984 » Tue Apr 10, 2018 9:53 pm
Taxed and it's now free after missing out last year by 22 days
Been talking to some landrover lads and they said I could of got free road tax done on the build date.
Learn something new everyday
walt1984
Postby transit tramp » Sun Apr 15, 2018 2:13 pm
Really enjoying this thread, looks great so far mate
transit tramp
Postby walt1984 » Wed Jul 11, 2018 11:07 am
Need to get back into habit of uploading photos before they get lost. Ive photos on 2 phones now.
A new sky light has been fitted over high bunk after old one started leaking and was looking passed its best.
After ringing localish caravan dealers to see if they had one in stock was surprised to find out they were only a couple of quid more than ebay. "What time you open till?"
"5pm"
" great ill set off now"
4pm and 11miles . got stuck in traffic and rolled into their yard with 8 mins to spare and £40 in my hand.
Nipped into shop and it was in darkness.
Shouted hello a couple of times when a guy came out of office asking what i was doing.
Explained id come to pick up a skylight id rang about a hour earlier.
"Sorry we're shut"
"But its not 5 yet!"
"I know but the tills are switched off"
I explained about traffic which he said " i know ive seen it.you will have to come back tomorrow at 10am"
Like shite i am.
After googling i found a smaller firm open at 8 next morning happy days.
The larger skylight has been replaced at some piont but started leaking so stripped it down.
The origanal must of been narrower so the hole in the roof had been cut wider with a blunt bread knife looking at the mess but didnt have any timber in to support the edges.
New timbers in and sealed with the propper non setting caravan sealer and tested with a hose pipe.
Water tight again ImageImage
Sent from my LG-M200 using Tapatalk
walt1984
Postby walt1984 » Wed Jul 11, 2018 11:27 am
On my way back from a rally a week ago there was such a clatter and tinging noise as i came round a little round about.
Pulled up to see what it was thinking id lost a hub cap.
Turn out to be head light surround that had come loose.
The green outer trim survived but car behind squashed the silver bezil.
I had one in stores id picked up on a auto jumble.
Differnt shade but will do for now.Image
walt1984
