the issue re electrical stuff is simply it uses sooooo much battery power, running engine to recharge what was used will inevitably use more fuel than just using fuel in first place, as losses through heat sound friction ect in an engine all make it unefficient compared to burning 50p worth of gas- prob cost £150 just do do same with leccy- unless your on hook up or abstracting as above
listen to what experienced guys are saying, gas gas gas.
ps if your worried bout gas safety- even seen a lead acid battery explode from a spark igniting hydrogen(#1 explosive gas)???
messy and acidic n not good if your enclosed!!!
ergo all reading this- do your batteries have gas tske off tubes still attached and routed out thru body or floor?? best get checking!!
lecture over!
