1978 mk 1 camper
Re: 1978 mk 1 camper
Postby walt1984 » Sun Jun 30, 2013 5:47 pm
done a little more today. new rocker cover gaskets and new lift pump as its been having hot starting problems but had spark :? .
and its passed its MOT (last week) but blew a indicator bulb on test! i think it was one of the last bulbs it came with the rest have blown and been replaced at some point over the last 12 months. :D
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby jonochap » Tue Jul 02, 2013 12:39 am
Lookin very cool, how did you fashion the spring helpers? They look like a good addition? :)
Owner of not so troubled puk :)
jonochap
Postby walt1984 » Tue Jul 02, 2013 3:08 pm
Hi, thanks. Spring helpers were already there but a lot flatter and we reshaped them with a oxy acetalean torch. I don't know if CI fitted them or a previous owner.
walt1984
Postby walt1984 » Tue Jul 16, 2013 9:34 pm
with the weather been dry and warm I've decided to tidy up and paint the inner wing that was repaired earlier this year.
armed with a aldi sander, filler and Halfords tins of paint.
the coil, ballast resister and starter solenoid have been mounted under the battery.
some of the wiring isn't the best so its been tided up, soldered, shrink wrapped and taped.
walt1984
Postby walt1984 » Thu Aug 22, 2013 7:58 am
been having what i thought was a over heating problem but its seems the gauge is reading wrong.
viewtopic.php?f=3&t=133987&p=1111588#p1111588
walt1984
Postby walt1984 » Sun Oct 20, 2013 8:34 am
not done anything lately its still parked outside the house sulking, going to plug in hook up so i can top up the starter battery (i can do this via the zig unit) as starters getting tiered so the battery needs to be good.
walt1984
Postby walt1984 » Sun Nov 17, 2013 5:48 pm
Had spare leaf springs nicked. Had a tidy up at workshop put em on trailer to take em to where camper is stored, took little lad to shop came back 5mins later to find they'd gone. :x :x :x :evil:
walt1984
Postby jonochap » Sun Nov 17, 2013 7:51 pm
Aww, thats just crap! So sorry to hear, i think thats the hardest part of any of this...chin up, at least they were spare :)
jonochap
Postby walt1984 » Mon Nov 18, 2013 8:54 am
Thanks Jono. Yeah could have been worse. they could have nicked the camper. it wouldn't be so bad if they nicked em to keep another transit on the road but I'm sure they will go for scrap.
walt1984
Postby walt1984 » Sun Mar 23, 2014 8:55 pm
progress is slow at the moment as the autosleeper is taking up any spare time. but have been colleting parts. now have a spare engine to rebuild then swap into it, a pattern drivers wing, new grille, got old fellas lady friend making some new curtains :D cheers sally, and someone has offered me some more front leaf springs so it will sit level (left to right) then ill get the originals refurbished for spares for either camper.
been up to shed to day and ran it up to temp. cant wait till we,re setting off to steam rally's with 2 mk1 campers :D :D
walt1984
Postby jonochap » Sun Mar 23, 2014 11:19 pm
Yip :) curtains and engines carry the same priority! :) :) :)
jonochap
Postby walt1984 » Sun Mar 30, 2014 8:13 pm
i sent the previous owners a link on email to keep track of progress of the CI and got a reply to say they would be following it.
so here is a link to the progress report of our latest addition.
viewtopic.php?f=58&t=142269
walt1984
Re: 1977 mk 1 camper
Postby davev6newman » Fri Apr 18, 2014 10:34 pm
walt1984 wrote:just typed up a update then lost it all somewhere. where the hell does it go ?
had chance to go and do a few things to camper but im limited to what i can do coz shed has no power or heat brrr.
things done.
stopped drivers side manifold blowing.
re-bushed clutch pedal. i think brake pedal has been done because pivot pipe will come out without taking clip off.
got hazards working. a loose wire in plug and a blown fuse.
got screen washers working. blown fuse and wire shorting out on bulk head.
fitted a ipod/cd radio.
pushed wiring grommets back into place.
made a start on rotten head light bowl.
new pedal bushes.
Hi, where did you get the pedal bushes from please
davev6newman
Postby walt1984 » Sat Apr 19, 2014 7:48 am
Hi, I got them from motomibil in Germany. Google search should bring it up. They have alsorts for classic Ford's.
walt1984
Postby walt1984 » Mon May 05, 2014 4:07 pm
Having a little trouble with charging unit. Its a dead short from from live to earth. I've taken cover off looking for anything that could have shorted . I disconnected something that bolts on to the case and now it works. Any electrical wizards ? ImageImageImageImage
walt1984
